Forum Topic - Error compiling network driver in QNX Momentics: (2 Items)
Error while compiling network driver in QNX monetics
I m trying to compile my network driver in momentics.I include <io-pkt/iopkt_driver.h> file.It throws the following
error.
C:/QNX641/target/qnx6/usr/include/io-pkt/dev/mii/miivar.h:82: error: field 'mii_media' has incomplete type
Please help me on this.
Thanks and Regards
K.Senthil
Error Logs
########## Compiling code in devnp-pe.so ##########
qcc -g -c -M -V gcc_ntox86 -DHOST -w9 -Wpointer-arith -Wshadow -DBUILD_TIME='Thu Nov 26 15:51:55 IST 2009' -
DPRIVATE_LABEL='' -DTARGET_x86 -IC:/ide-4.6-workspace/includes -I./includes -IC:/ide-4.6-workspace/software/includes -IC
:/ide-4.6-workspace/ThirdParty/libxml2/include -IC:/ide-4.6-workspace/ThirdParty/curl/usr/include -IC:/ide-4.6-workspace
/includes -IC:/ide-4.6-workspace/common IC:/QNX641/target/qnx6/usr/include/io-pkt -DNDEBUG -DVARIANT_dll -DBUILDENV_qss
-shared -o objs/x86/pedriver.o -c src/pedriver.c
In file included from C:/QNX641/target/qnx6/usr/include/io-pkt/iopkt_driver.h:65,
                 from src/pedriver.c:16:
RE: Error compiling network driver in QNX Momentics
iopkt_driver.h is NOT meant to be a complete
list of header files, sufficient for all drivers
to compile.  It's just a starting point.
For example, if we look at sys/dev_qnx/i82544/i82544.h:
-- cut --
    396 #include <io-pkt/iopkt_driver.h>
    397 #include <stdio.h>
    398 #include <errno.h>
    399 #include <atomic.h>
    400 #include <unistd.h>
    401 #include <stdlib.h>
    402 #include <string.h>
    403 #include <sys/mman.h>
    404 #include <sys/types.h>
    405 #include <sys/siginfo.h>
    406 #include <sys/syspage.h>
    407 #include <sys/neutrino.h>
    408 #include <sys/mbuf.h>
    409 #include <sys/syslog.h>
    410
    411 #include <net/if.h>
    412 #include <net/if_dl.h>
    413 #include <net/if_types.h>
    414 #include <net/if_ether.h>
    415 #include <net/if_media.h>
    416 #include <sys/io-pkt.h>
    417 #include <sys/cache.h>
    418 #include <sys/callout.h>
    419 #include <hw/inout.h>
    420 #include <drvr/mdi.h>
    421 #include <drvr/eth.h>
    422 //#include <drvr/nicsupport.h>
    423 #include <hw/nicinfo.h>
    424 #include <sys/device.h>
    425 #include <siglock.h>
    426
    427 #include <dev/mii/miivar.h>
    428 #include <eeprom.h>
-- cut --
Now, I am not saying that you need all of
the above header files included for your
particular driver.  You might need less.
You might need more, depending upon what
your particular driver does, and how it
does it.
But for this particular error, you might
look at including net/if_media.h
When you are writing drivers, it can really
really really help to look at the source of
other, similar drivers.
aboyd
aboyd
