Forum Topic - Packet filter compilation in Momentics: (7 Items)
I had compile the lsm packet filter code in QNX momentics,compilation is successful but while linking the following are
the  errors
ake[2]: Entering directory `D:/Paticla/Compilation_check/lsm/x86/dll'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `D:/Paticla/Compilation_check/lsm/x86/dll'
C:/QNX641/host/win32/x86/usr/bin/make -j 1 -Co -fMakefile all
make[2]: Entering directory `D:/Paticla/Compilation_check/lsm/x86/o'
C:/QNX641/host/win32/x86/usr/bin/qcc -Vgcc_ntox86 -c -Wc,-Wall -Wc,-Wno-parentheses  -O          -DNDEBUG   -I. -ID:/
Paticla/Compilation_check/lsm/x86/o -ID:/Paticla/Compilation_check/lsm/x86 -ID:/Paticla/Compilation_check/lsm -IC:/
QNX641/target/qnx6/usr/include     -DBUILDENV_qss  D:/Paticla/Compilation_check/lsm/packfil.c
C:/QNX641/host/win32/x86/usr/bin/rm -f  D:/Paticla/Compilation_check/lsm/x86/o/lsm
C:/QNX641/host/win32/x86/usr/bin/qcc -Vgcc_ntox86     -oD:/Paticla/Compilation_check/lsm/x86/o/lsm    lsm.o    packfil.o
   -L . -L C:/QNX641/target/qnx6/x86/lib -L C:/QNX641/target/qnx6/x86/usr/lib  -Wl,--rpath-link . -Wl,--rpath-link C:/
QNX641/target/qnx6/x86/lib -Wl,--rpath-link C:/QNX641/target/qnx6/x86/usr/lib
packfil.o: In function `pfil_entry':
packfil.c:(.text+0x264): undefined reference to `pfil_head_get'
packfil.c:(.text+0x28e): undefined reference to `pfil_add_hook'
packfil.c:(.text+0x2ae): undefined reference to `pfil_add_hook'
make[2]: Leaving directory `D:/Paticla/Compilation_check/lsm/x86/o'
packfil.c:(.text+0x2c2): undefined reference to `pfil_head_get'
C:/QNX641/host/win32/x86/usr/bin/make -j 1 -Co-g -fMakefile all
packfil.c:(.text+0x2e8): undefined reference to `pfil_add_hook'
packfil.c:(.text+0x308): undefined reference to `pfil_add_hook'
packfil.o: In function `iface_hook':
packfil.c:(.text+0x416): undefined reference to `pfil_head_get'
packfil.c:(.text+0x440): undefined reference to `pfil_remove_hook'
packfil.c:(.text+0x460): undefined reference to `pfil_remove_hook'
packfil.c:(.text+0x474): undefined reference to `pfil_head_get'
packfil.c:(.text+0x49a): undefined reference to `pfil_remove_hook'
packfil.c:(.text+0x4ba): undefined reference to `pfil_remove_hook'
cc: C:/QNX641/host/win32/x86/usr/bin/ntox86-ld caught signal 1
make[2]: *** [D:/Paticla/Compilation_check/lsm/x86/o/lsm] Error 1
make[2]: Target `all' not remade because of errors.
Please help me on this...
Thanks and Regards
K.Senthil
Re: Packet filter compilation in Momentics
On Mon, Nov 16, 2009 at 12:01:50PM -0500, Senthil K wrote:
are the  errors
.o   -L . -L C:/QNX641/target/qnx6/x86/lib -L C:/QNX641/target/qnx6/x86/usr/lib  -Wl,--rpath-link . -Wl,--rpath-link C:/
This is probably fine.  These will be resolved in
io-pkt itself.  Our drivers and lsms have the
following in their Makefile to suppress these.
LDFLAGS+=-Wl,--allow-shlib-undefined
where i have  to add,there are common.mk file and make file.
Thanks and Regards
K.Senthil
AFAIK packfil.c is not QNX supported code so I have no idea what you're
trying to do. But those symbols are in the stack. Did you want to build
a dll or link your code in statically?
I see below that your x86/dll build is either not happening, or has
happened successfully before. Note: With a dll you'll leave those
symbols to resolve with the stack at load. You'll need to build with
shared library options (see also Sean's post...).
As it is, looks like your x86/o build is trying to link a final
executable "lsm" and is failing because it would need to link with the
stack.
Hope this helps!
/P
Senthil K wrote:
are the  errors
> Thanks and Regards
> K.Senthil
> Networking Drivers
> http://community.qnx.com/sf/go/post42027
Now i tried in QNX host machine,instead of momentics here also same problem.
I added "LDFLAGS+=-Wl,--allow-shlib-undefined" in .qnx_internal.mk file but still i m getting.
make[2]: Entering directory `/home/senthil/QNX_6.4.1/sys/cpss-packfil/x86/o'
/usr/qnx641/host/qnx6/x86/usr/bin/qcc -Vgcc_ntox86 -c -Wc,-Wall -Wc,-Wno-parentheses  -O          -DNDEBUG   -I. -I/home
/senthil/QNX_6.4.1/sys/cpss-packfil/x86/o -I/home/senthil/QNX_6.4.1/sys/cpss-packfil/x86 -I/home/senthil/QNX_6.4.1/sys/
cpss-packfil -I/usr/qnx641/target/qnx6/usr/include/io-pkt -I/usr/qnx641/target/qnx6/usr/include     -DBUILDENV_qss  /
home/senthil/QNX_6.4.1/sys/cpss-packfil/packfil.c
/bin/rm -f  /home/senthil/QNX_6.4.1/sys/cpss-packfil/x86/o/cpss-packfil
/usr/qnx641/host/qnx6/x86/usr/bin/qcc -Vgcc_ntox86     -o/home/senthil/QNX_6.4.1/sys/cpss-packfil/x86/o/cpss-packfil
packfil.o   -L . -L /usr/qnx641/target/qnx6/x86/lib -L /usr/qnx641/target/qnx6/x86/usr/lib  -Wl,--rpath-link . -Wl,--
rpath-link /usr/qnx641/target/qnx6/x86/lib -Wl,--rpath-link /usr/qnx641/target/qnx6/x86/usr/lib
/usr/qnx641/target/qnx6/x86/lib/crt1.o:(.text+0x4): undefined reference to `main'
/usr/qnx641/target/qnx6/x86/lib/crt1.o: In function `_start':
(.text+0x86): undefined reference to `main'
packfil.o: In function `packetFilterEntry':
packfil.c:(.text+0xa): undefined reference to `eth_input_pfil_hook'
packfil.c:(.text+0x26): undefined reference to `pfil_add_hook'
packfil.o: In function `receivePacketHandler':
packfil.c:(.text+0x138): undefined reference to `stk_ctl'
packfil.c:(.text+0x14a): undefined reference to `m_free_wtp'
packfil.c:(.text+0x176): undefined reference to `stk_ctl'
packfil.c:(.text+0x188): undefined reference to `m_free_wtp'
cc: /usr/qnx641/host/qnx6/x86/usr/bin/ntox86-ld error 1
make[2]: *** [/home/senthil/QNX_6.4.1/sys/cpss-packfil/x86/o/cpss-packfil] Error 1
make[2]: Leaving directory `/home/senthil/QNX_6.4.1/sys/cpss-packfil/x86/o'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/home/senthil/QNX_6.4.1/sys/cpss-packfil/x86'
make: *** [all] Error 2
Please help me.
Thanks and Regards
K.Senthil
On Tue, Nov 17, 2009 at 02:02:50AM -0500, Senthil K wrote:
home/senthil/QNX_6.4.1/sys/cpss-packfil/x86/o -I/home/senthil/QNX_6.4.1/sys/cpss-packfil/x86 -I/home/senthil/QNX_6.4.1/
sys/cpss-packfil -I/usr/qnx641/target/qnx6/usr/include/io-pkt -I/usr/qnx641/target/qnx6/usr/include     -DBUILDENV_qss
/home/senthil/QNX_6.4.1/sys/cpss-packfil/packfil.c
That option isn't being passed to your link so it wasn't
added to the correct spot.
They're just warnings so you can ignore them.
I just noticed you're now making an x86/o variant.  At the
start of this thread it was a dll which  is what it should
be for a lsm.  In the dll case the references beginning at
eth_input_pfil_hook above are resolved in io-pkt itself.
