Forum Topic - ioctl operation in sample ethernet driver: (11 Items)
I have added a few new ioctl commands in sam_ioctl function in sample ethernet driver.
For accessing
1.I wrote test application to create a s = socket(AF_INET,SOCK_DGRAM,0).
2.update the interface name as sam0 in struct ifreq structure.
3.invoked ioctl function ioctl(s,MY_CMD,&ifreq).
The following error
#./test
[Operation not Supported ]
Please tell me how to process my ioctl commands.
Regards
K.Senthil
Re: ioctl operation in sample ethernet driver
Rename your executable to sth else, not test, test as a executable name was not supported some time ago.
PKY
>  driver.
> For accessing
> The following error
> #./test
> Regards
> K.Senthil
I have changed.
but still ..
#./sth
 iotcl failed[Operation not supported]
Regards
K.Senthil
Can you please respond this mail.
Thanks and Regards
K.Senthil
On Tue, Oct 20, 2009 at 06:40:57AM -0400, Senthil K wrote:
> For accessing
> The following error
> #./test
I suggest firing up the debugger.  Depending
on how MY_CMD is defined it may be handled
higher up the stack.  In general the first
step is do populate the (struct ifnet *)->if_ioctl
callout when registering your driver.
RE: ioctl operation in sample ethernet driver
> Depending on how MY_CMD is defined
> it may be handled higher up the stack
IIRC correctly the flow to the driver ioctl
is something like this:
    startproc()
    tcpip_devctl()
    soo_ioctl()
    ifioctl()
aboyd
Hi Sean,
#define MY_CMD _IOW('p',1,struct ifreq)
I register the sam_ioctl function in the driver.
strcpy(ifreq.ifr_name,"sam0");
if i do ioctl(s,MY_CMD,&ifreq) function it should call  sam_ioctl function right?
Regards
Senthil
On Wed, Oct 21, 2009 at 09:52:01AM -0400, Senthil K wrote:
> Hi Sean,
No. 'p' class ioctls hit generic handling
further up and the stack has no knowledge
of this ioctl at that level.
Hi Sean,
Please tell me how can i define MY_CMD.
Regards
Senthil
Please tell me how to define user commands for ioctl.
Thanks and Regards
Senthil
Hi Sean,
Thanks a lot....
I tried #define MY_CMD _IOWR('i',1,struct ifreq)
Its working fine..
Regards
Senthil
