Forum Topic - Building native drivers on Momentics 6.4: (3 Items)
I have the core networking source with me.i want to build the 85xx tsec driver alone and i was able to build the 85xx
tsec driver from command line.Is it possible to import the driver source to momentics ide 6.4? If it is possible how can
 i do it?
RE: Building native drivers on Momentics 6.4
Given that you currently need all of the io-pkt source checked out, we
don't recommend it.  If you like, you should be able to point the IDE at
the mpc85xx directory as a standard make C project.
From: Vijayanandham Kamalasekaran [mailto:community-noreply@qnx.com]
Sent: Wednesday, November 12, 2008 2:40 AM
To: builds-networking
Subject: Building native drivers on Momentics 6.4
driver alone and i was able to build the 85xx tsec driver from command
it is possible how can i do it?
Builds
http://community.qnx.com/sf/go/post16439
Re: RE: Building native drivers on Momentics 6.4
Ok craig,I will try to import the mpc85xx folder as a standard make c project.Will post if it does not build.
