Chris Li
A question about fail to play tracks from a USB stick on VMware by using Aviage MM 1.2
Chris Li
07/23/2009 3:44 AM
post34372
Just wonder anyone can give me some hints about fail to play tracks from a USB stick on a VMware target machine which
running QNX neutrino 6.4.1 with Aviage MM 1.2. Details as follows:
After successfully built up a track session, and tried playing tracks on that, the MME delivery some error messages as:
MME_EVENT_PLAYSTATE
MME_EVENT_TRKSESSION
MME_EVENT_TRKSESSIONVIEW_UPDATE
MME_EVENT_PLAY_ERROR
MME_PLAY_ERROR_UNSUPPORTEDCODEC
MME_EVENT_PLAYSTATE.
MME_EVENT_FINISHED
From the above error messages, I couldn't figure out what caused the failure.
Then I tried using sloginfo (can see below for details):
Jul 23 02:48:43 5 20 1 io-media-generic: Received signal 15
Jul 23 02:48:44 5 27 200 MDP:mdp_mgr_init(264): Starting metadata plug-in initialization.
Jul 23 02:48:44 5 27 0 MME:dbs_init(469): Starting database synchronizer initialization.
Jul 23 02:48:44 2 19 900 devb-umass 1.00A (May 20 2009 17:07:26)
Jul 23 02:48:44 2 5 0 libcam.so (May 20 2009 17:06:08) bver 6040100
Jul 23 02:48:45 2 5 100 cam-disk.so (May 20 2009 17:06:11)
Jul 23 02:48:46 1 27 0 MME:ocb_lock(151): Concurrent MME handle usage pid 3264525, tid 3!
Jul 23 02:48:47 5 20 1 io-media-generic/mmf: writer hint snd:* found
Jul 23 02:48:47 5 20 1 io-media-generic/trackplayer: Skipping video subgraph because there is no video device
specified.
Jul 23 02:48:47 5 20 1 io-media-generic/mmf: Configuring the queue for -1 bytes, lw = 0, hw = 0.
Jul 23 02:48:47 5 20 1 io-media-generic/trackplayer: Skipping video subgraph because there is no device
specified.
Jul 23 02:48:47 5 20 1 io-media-generic/mmf: Configuring the queue for 2116800 bytes, lw = 423360, hw =
1693440.
Jul 23 02:48:47 5 20 1 io-media-generic/aoi: audio_writer using output device: '/dev/snd/pcmPreferredp'
Jul 23 02:48:47 3 20 1 io-media-generic/aoi: audio_writer snd_pcm_open_name failed: No such file or directory
Jul 23 02:48:47 4 20 1 io-media-generic/trackplayer: Couldn't find a suitable decoder filter, mmerr=4047
Jul 23 02:48:47 2 20 1 io-media-generic/trackplayer: Error 10004, 2, 4047:
Jul 23 02:48:47 2 20 1 io-media-generic/trackplayer: Couldn't create a linking filter for parsed stream
Jul 23 02:48:47 2 27 0 MME:_attachinput(3694): Could not attach input (/fs/usb0///
I'llBeMissingYou_PuffDaddy_withArtWork.wav) to co
ntrolcontext default (fid=1). errno=5
Jul 23 02:48:47 2 27 0 MME:_play(3150): Could not attach file '/fs/usb0///
I'llBeMissingYou_PuffDaddy_withArtWork.wav'
specified.
specified.
1693440.
Jul 23 02:48:47 5 20 ...
