Chris Li
mme_metadata_getinfo_current() returns misleading album art info for a track without any album arts on iPods
Chris Li
06/04/2009 10:01 PM
post30914
Just found an issue of mme_metadata_getinfo_current() returns misleading album art info for a track without any album
arts on iPods.
For the current playing track without an album art on the connected iPod, by using mme_metadata_getinfo_current() to
query the album art info, it returns the following info from the MME_EVENT_METADATA_INFO event:
ptMME_event_metadata_info->error = 22
ptMME_event_metadata_info->metadata.len = 0
(ptMME_event_metadata_info is a pointer pointing to mme_event_metadata_info_t)
The error=22 means invalid argument, it is a little bit misleading here for the track without an album art. Anyway, it
is not too bad because we still can refer to the metadata.len member which equal to 0 for a track without any album art.
For s a track it does have album art, mme_metadata_getinfo_current() will return the album art info as follows:
ptMME_event_metadata_info->error = 0
ptMME_event_metadata_info->metadata.len = 434
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<container type="file">
<track index="0">
<audio>
<stream index="0"/>
</audio>
<images>
<image index="0" loadable="true">
<format width="100" height="100" size="20070" mimetype="image/bmp"/>
</image>
<image index="1" loadable="true">
<format width="200" height="200" size="80070" mimetype="image/bmp"/>
</image>
</images>
</track>
</container>
It is perfectly fine for a track with an album art. However, the problem is that once mme_metadata_getinfo_current()
successfully returns an album art info for a track with an album art, it will always report the same info as above for
the subsequent playing tracks, no matter the track has an album art or not.
After the problem occur, we have no idea to know whether the current playing track has an album art or not through the
return info of mme_metadata_getinfo_current(). That means we have to use mme_metadata_image_load() to attempt to load
album arts for every song according to the above misleading return info. For the one without album art,
mme_metadata_image_load() will return a void URL. That is not bad, however, the annoying thing is it still generates a
void image file in the corresponding location(in my case, /tmp/FAA368087.png) which can not be read by any image viewer.
Can see the void image as attached.
Just wonder any solutions for that, thanks.
Chris
