Forum Topic - QDB error: (4 Items)
QDB error
I have used cifs to mount the windows shared directory on the "/". Then created "/db" directory for the QDB.
I am geting disk io error.
 # qdb -c /db/qdb.cfg -v -Otempstore=/fs/tmpfs -Rset
qdb: processing [mme_library]/db/mme_library.sql - disk I/O error
I tried with "/tmp/mme_library.sql" and /tmp/mme_library". I am getting the same error.
I tried before on some other board where Nand flash was there. It works there.
Any idea what is the issue?
Is it that it can't work with CIFS file system?
- Venkat
Re: QDB error
On Mon, 1 Jun 2009, Venkatarao Patnaik Balivada wrote:
>Hi,
This should probably be extended to include cifs as well:
Database directory
The QDB database directory can be on any QNX or POSIX filesystem with
read/write access (including memory-based filesystems, such as tmp-fs). QDB
can run from QNX filesystems visible via Qnet, but can not run from an NFS
filesystem.
Peter
>the same error.
>there.
>- Venkat
>General
>http://community.qnx.com/sf/go/post30423
Re: QDB error
Thanks Peter. Earlier I tried /dev/shmem, it didn't work. It works with tmpfs!
Re: QDB error
Glad to help. We updated the docs to explictly mention cifs as well as nfs
now as a location that can't be used for the database.
The docs should already cover /dev/shmem not working.
Peter
>General
>http://community.qnx.com/sf/go/post30496
