Peter Martin
Re: Found a strange behavior while using mme_play_resume_msid( )
for resuming playback on 1st Gen iTouch
Peter Martin
05/13/2009 10:34 AM
post29360
On Tue, 12 May 2009, Chris Li wrote:
>Hi,
>Just found a strange behavior while using mme_play_resume_msid( ) (An API
>function of Aviage Multimedia Suite) for resuming playback on 1st Gen
>iTouch (in Firmware 1.1.5 or below). The scenario is as follows: In most
>cases, the iTouch can only be successfully resumed playback in the first
>time and failed after that. For example, after successfully resumed
>playback by using mme_play_resume_msid( ), if disconnect the iTouch and
>re-connect it to the accessory, it will failed to resume playback and will
>receive MME_PLAY_ERROR_NOTSPECIFIED and MME_EVENT_FINISHED_WITH_ERROR MME
>events. The worse thing is, the functionality of the iTouch is also
>affected after the error occurs. Once failed to resume playback, if
>disconnect the iTouch, the attempting track on the iTouch can not be
>toggled pause and play in Now Playing menu. It looked like something wrong
>with iTouch for playing the now playing track and have to go to other menu
>to select another track to play, then the iTouch has full functionality
>again.
>Have tried some other iPods like Nano, Classic and 3G iPhone, seems the
>odd behavior only happens on iTouch (1st generation, model MA627ZP,
>firmware 1.1.5 or below).
>BTW, we are currently using the latest Aviage MME 1.2 Alpha release (build
>20.14)
Are you able to check the sampling rate on the track that you're trying to
resume? We have found and corrected an issue where if you were trying to
resume playback of a track that was not sampled at 44.1 then it may not
work. (PR 67830)
We've also come across a few issues with playback and behaviour using
itouches with the 1.x stream of firmware that we haven't been able to
reproduce on itouches using the 2.x stream of firmware. These issues are
still under investigation.
Thanks for the detailed method for reproducing the issue. I'll see if I can
confirm similar behaviour here.
Peter
>How To Reproduce:
>1) Select a track to play on iTouch.
>2) Connect the iTouch to accessory which running Aviage Multimedia Suite.
>3) By using mme_play_resume_msid( ) API function, the current playing
>track on iTouch can be resumed playing successfully.
>4) Disconnected the iTouch from the accessory.
>5) Re-start the Aviage Multimedia Suite (The purpose of that is just make
>sure the issue is not caused by some data bases or track sessions
>conflict.)
>6) Reconnected the iTouch to the accessory again, most of cases will fail
>to resume playback on this kind of iPod and will receive
>MME_PLAY_ERROR_NOTSPECIFIED and MME_EVENT_FINISHED_WITH_ERROR MME events.
>It looks like this is an iPod issue, but still looking forward the confirm or other info about this. Furthermore, post
it here maybe can help to complement the iPod compatibility list for the formal Avaige Multimedia Suite release.
>Regards,
>Chris
>General
>http://community.qnx.com/sf/go/post29324
