Prem Mallappa
03/06/2009 8:04 AM
post23747
Just downloaded the component .. trying to compile..
In file included from /qnx/src/multimedia/lib/curl/urldata.h:79,
from /qnx/src/multimedia/lib/curl/connect.c:75:
/qnx/src/multimedia/lib/curl/timeval.h:38: error: redefinition of 'struct timeval'
In file included from /qnx/src/multimedia/lib/curl/connect.c:75:
/qnx/src/multimedia/lib/curl/urldata.h:294: error: field 'serv_addr' has incomplete type
/qnx/src/multimedia/lib/curl/connect.c:142:2: error: #error "no non-blocking method was found/used/set"
/qnx/src/multimedia/lib/curl/connect.c: In function 'Curl_connecthost':
/qnx/src/multimedia/lib/curl/connect.c:490: error: dereferencing pointer to incomplete type
/qnx/src/multimedia/lib/curl/connect.c:517: error: dereferencing pointer to incomplete type
/qnx/src/multimedia/lib/curl/connect.c:519: error: storage size of 'serv_addr' isn't known
/qnx/src/multimedia/lib/curl/connect.c:524: error: dereferencing pointer to incomplete type
/qnx/src/multimedia/lib/curl/connect.c:525: error: invalid application of 'sizeof' to incomplete type 'struct in_addr'
/qnx/src/multimedia/lib/curl/connect.c:526: error: dereferencing pointer to incomplete type
/qnx/src/multimedia/lib/curl/connect.c:527: warning: implicit declaration of function 'htons'
/qnx/src/multimedia/lib/curl/connect.c:519: warning: unused variable 'serv_addr'
/qnx/src/multimedia/lib/curl/connect.c:582: warning: implicit declaration of function 'close'
/qnx/src/multimedia/lib/curl/connect.c:592: error: dereferencing pointer to incomplete type
cc: /qnx/qnx640/host/linux/x86/usr/lib/gcc/arm-unknown-nto-qnx6.4.0/4.2.4/cc1 error 1
