Forum Topic - MmSetDefaultClock: (9 Items)
MmSetDefaultClock
I was trying to build my own graph using MME.
The function MMSetDefaultClock giving me a link error :
(.text+0x3bc): undefined reference to `MmSetDefaultClock'
But all other functions are getting linked !
I am including libmmedia.so as a shared library.
Can somebody help me with this ?
Arun
Re: MmSetDefaultClock
You don't create a graph if you are using the MME.  MME talks to io-media
which in turn uses MMF to play back the content.  Do you have the MME
documentation?
On 11-11-30 11:06 AM, "Arun Johnson" <community-noreply@qnx.com> wrote:
>Hi,
>Thanks,
>Arun
>General
>http://community.qnx.com/sf/go/post90357
sorry,
What I meant is I am trying to create my own graph using the library.
that's when I got the error.
Arun
MMF is not normally a customer-facing API.  Also, there should be no
reason to call that function.  What are you trying to accomplish?
Are you using Aviage, or the Blackberry NDK?
On 11-11-30 11:12 AM, "Arun Johnson" <community-noreply@qnx.com> wrote:
>sorry,
>Thanks,
>Arun
>General
>http://community.qnx.com/sf/go/post90359
I am trying to learn about the library using examples from QNX Neutrino, Multimedia Developer's guide. Specifically Ex:
"playing MP3". I was learning to use the
media reader, wave parser and audio writer to get playing a wave file. I assume this is all I need to play a wave file.
io-audio is functional in my system and I am able to play wave files using the wave utility. I am trying to achieve the
same functionality with MMF. But this function is giving me a linking error.
Arun
I am using Aviage for the purpose.
If you are using Aviage, MMF is not a customer-facing API.  Why have you
chosen that?  Is there something the MME is not able to do for you?
>Thanks
>General
>http://community.qnx.com/sf/go/post90364
No I wanted to have an understanding of the framework internally so that I can write my own player.
by commenting out MmSetDefaultClock, I am able to get the graph started
but Mmstatus returns MM_STATUS_ERROR.
Is there anything else I need to consider for plying just a wave file.
you help is reapply appreciated
thanks,
arun
As I said earlier.  MMF is not a customer-facing, or supported API for
Aviage.  Sorry.  If you want to play media using Aviage, please use the
MME.
>thanks,
>arun
>General
>http://community.qnx.com/sf/go/post90369
