Multimedia
Forum Topic - armle targets: (2 Items)
armle targets
I am working on using Aviage on armle target. With core package, I realized that there is no gf_writer.
Is it possible to display video in arm target ? I have edited mme_data.sql to add another video output device and
attached the zoneoutput to this device.
my mme_sql is as follows:
INSERT INTO outputdevices(type, permanent, name, devicepath) VALUES(1, 1, 'default_audio', 'snd:/dev/snd/pcmPreferredp')
INSERT INTO outputdevices(type, permanent, name, devicepath) VALUES(2, 1, 'default_video', 'gf:0000,0000');
INSERT INTO zones(zoneid, name) VALUES(1, 'defaultzone');
INSERT INTO zoneoutputs(zoneid, outputdeviceid) SELECT 1, outputdeviceid FROM outputdevices WHERE name='default_audio';
INSERT INTO zoneoutputs(zoneid, outputdeviceid) SELECT 1, outputdeviceid FROM outputdevices WHERE name='default_video';
INSERT INTO renderers(path) VALUES('/dev/io-media');
INSERT INTO controlcontexts(zoneid, rendid, name) VALUES( 1, 1, 'default' );
Its giving me an error for could not attach parser while playing mp4 video. I know that the mp4_parser is there in the
correct location and it is liked properly.
Its also giving me an error "output device type 2 not supported."
Is there a way in Aviage to attach my own h.264 decoder that has DSP implementation ? if yes, can you point me to the
right direction ?
Is there any interface format to write my decoder so as to make aviage linked to it ? I didnt see any documentation
about writing our own decoder
Re: armle targets
Hi
I will comment on some of your points below.
gf_writer was only shipped with x86 in 1.2 as there was no available ARM
video decoder.
In general, a 3rd party video decoder must be wrapped to comply with our
Multimedia Framework.
This is not a trivial task and is typically done by QNX via custom
engineering.
There is no standard documentation on this.
I would recommend contacting your support contact if you need to pursue
this.
On 11-11-16 10:29 AM, "Arun Johnson" <community-noreply@qnx.com> wrote:
>Hi,
>mme_data.sql to add another video output device and attached the
>'default_audio', 'snd:/dev/snd/pcmPreferredp');
>video. I know that the mp4_parser is there in the correct location and it
>is liked properly.
>implementation ? if yes, can you point me to the right direction ?
>linked to it ? I didnt see any documentation about writing our own
>decoder
>General
>http://community.qnx.com/sf/go/post90132
