Tysen Moore
09/07/2010 10:58 AM
post66140
I'm seeing some errors when doing simple QDB requests. I am seeing “Input/Output error”, code 5. This is a simple
database with a simple query. I’ve read from the QDB documentation that these are actually SQLite error messages coming
from QDB. I’ve also seen that a bug exists in SQLite which can erroneously cause this error: https://issues.rpath.
com/browse/RPL-1729. I was wondering if anyone had more information on the possible cause for this error? Also, what
version of SQLite does QDB use? This problem is creating a lot of problems because critical data is not reliably
returned from QDB. Any added information you could give would be much appreciated. As always thanks for the time and
help.
The Query made is similar to:
SELECT value FROM keyvalueTbl WHERE key = 'CurrentStr';
The database is configured as:
[keyvalue]
Filename = /fs/etfs/usr/share/misc/keyvalue
Base Schema = /etc/keyvalue.sql
Data Schema = /etc/keyvalue_data.sql
Compression = bzip
# use -i qdb
NAME=qdb
DESCRIPTION=QNX SQL Database Server
DATE=2010/04/26-18:05:44-EDT
STATE=stable
HOST=spare1
USER=builder
VERSION=20.21
TAGID=3336@295193
# use -i /usr/lib/libsqlite3.so.1
NAME=libsqlite3.so
DESCRIPTION=SQLite Library
DATE=2010/04/26-15:51:08-EDT
STATE=stable
HOST=spare1
USER=builder
VERSION=20.21
TAGID=3336@295193
NAME=libsqlite3.so
STATE=stable
HOST=spare1
USER=builder
VERSION=20.21
TAGID=3336@295193
