Mark Schuck
iPod video 'connection' selection not taking effect
Mark Schuck
04/30/2010 4:29 PM
post53345
We recently updated to the MME/iPod v1.2.1 drivers (on an ARM LE platform). We used to be able to use the preference
'connection/component/k' in the startup of io-fs-media in order to get the iPod Touch to use the component output. This
no longer seems to take effect. After i start up the driver i've used the function mme_device_get_config() and the
returned XML data structure says:
'<connection value="composite" valuetype="enum" modifiable="no" alternatives="none,composite,svideo,component"/>'
(see the attachement)
which clearly is not what i specified in my startup of io-fs-media:
io-fs-media -dipod,transport=usb:sconfig:busno=00:devno=01:audio=/dev/snd/ipod-00-01,pref=lineout/on/k:video/on/k:screen
/fit/k:format/ntsc/k:ratio/wide/k:connection/component/k:caption/off/r,darates=+,mount=/fs/ipod0,playback,acp=i2c:path=/
dev/i2c3,fnames=short
I've also tried this on an iPod Nano with the same behavior.
Is this no longer the preferred method of setting the preferences?
