Daniel Endres(deleted)
"Skipping file because it is known to be not playable" endless loop
02/16/2011 5:54 AM
post83198
Hi all,
I've just ran into an issue regarding the automatic skipping of already known unplayable tracks (just did a touch to
create some files). In my use case i had a tracksession consisting of ONLY unplayable tracks. If I fire a 'mmecli
play_extended offset 0' on this tracksession, the mme skips as assumed from track to track with the message:
'Skipping file because it is known to be not playable. fid=251, filename='/net/mmx.mibhigh.net/fs/sdb0//Gemischt/error
testing/only corrupt files//3empty.mp3'
Unfortunately the mme doesn't recognize the end of the tracksession and therefore loops until forever. At this point the
mme is unresponsive as well. So it's not possible to call a stop or any other command.
There are eleven entries within my tracksession:
Jan 01 01:26:04 5 27 0 MME:_play(3229): Skipping file because it is known to be not playable. fid=249,
filename='/net/mmx.mibhigh.net/fs/sdb0//Gemischt/error testing/only corrupt files//1empty.mp3'
Jan 01 01:26:04 5 27 0 MME:_play(3229): Skipping file because it is known to be not playable. fid=250,
filename='/net/mmx.mibhigh.net/fs/sdb0//Gemischt/error testing/only corrupt files//2empty.mp3'
Jan 01 01:26:05 5 27 0 MME:_play(3229): Skipping file because it is known to be not playable. fid=251,
filename='/net/mmx.mibhigh.net/fs/sdb0//Gemischt/error testing/only corrupt files//3empty.mp3'
Jan 01 01:26:05 5 27 0 MME:_play(3229): Skipping file because it is known to be not playable. fid=252,
filename='/net/mmx.mibhigh.net/fs/sdb0//Gemischt/error testing/only corrupt files//4empty.mp3'
Jan 01 01:26:05 5 27 0 MME:_play(3229): Skipping file because it is known to be not playable. fid=253,
filename='/net/mmx.mibhigh.net/fs/sdb0//Gemischt/error testing/only corrupt files//5empty.mp3'
Jan 01 01:26:05 5 27 0 MME:_play(3229): Skipping file because it is known to be not playable. fid=254,
filename='/net/mmx.mibhigh.net/fs/sdb0//Gemischt/error testing/only corrupt files//6empty.mp3'
Jan 01 01:26:05 5 27 0 MME:_play(3229): Skipping file because it is known to be not playable. fid=255,
filename='/net/mmx.mibhigh.net/fs/sdb0//Gemischt/error testing/only corrupt files//7empty.mp3'
Jan 01 01:26:05 5 27 0 MME:_play(3229): Skipping file because it is known to be not playable. fid=246,
filename='/net/mmx.mibhigh.net/fs/sdb0//Gemischt/error testing/only corrupt files//8empty.mp3'
Jan 01 01:26:05 5 27 0 MME:_play(3229): Skipping file because it is known to be not playable. fid=247,
filename='/net/mmx.mibhigh.net/fs/sdb0//Gemischt/error testing/only corrupt files//10empty.mp3'
Jan 01 01:26:05 5 27 0 MME:_play(3229): Skipping file because it is known to be not playable. fid=248,
filename='/net/mmx.mibhigh.net/fs/sdb0//Gemischt/error testing/only corrupt files//11empty.mp3'
Jan 01 01:26:05 5 27 0 MME:_play(3229): Skipping file because it is known to be not playable. fid=249,
Jan 01 01:26:06 5 27 0 MME:_play(3229): Skipping file because it is known to be not playable. fid=250,
Jan 01 01:26:06 5 27 0 MME:_play(3229): Skipping file because it is known to be not playable. fid=251,
Jan 01 01:26:06 5 27 0 MME:_play(3229): Skipping file because it is known to be not playable. fid=252,
Jan 01 01:26:06 5 27 0 MME:_play(3229): Skipping file because it is known to be not playable. fid=253,
Jan 01 01:26:06 5 27 0 MME:_play(3229): Skipping file because it is known...
