Forum Topic - Creating an ipod-tracksession : (3 Items)
Hi all,
How do i create an iPod tracksession right?
what i do is the following:
first i create a filebased tracksession with the msid of the ipod
- mme_newtrksession(mme_hdl, MME_PLAYMODE_FILE, sqlStmt)
 with sqlStmt = "SELECT fid from library WHERE ftype=5 AND msid=(msid_of_ipod)"
then I set the created tracksession with its returned id in mme_settrksession
afterwards I call mme_set_trksession_files() with following path:
/Music/Artists/item~0/item~0/item~0 ( first item~0=AlbumA, sec. is ArtistA and third is the Song itself)
Here my first question: Is the path given to the mme in the described form right?
(The function returns no error)
When calling mme_play(0) or mme_play_offset(0), no playback is started.
The sloginfo reports the error: "Could not create graph..." see attached sloginfo.txt (the log-level was set to "mmecli
set_debug 8 0"
Thanks for any help.
Attachment: Text sloginfo.txt 6.15 KB
Re: Creating an ipod-tracksession
Is io-media running with a mountpoint of /dev/io-media/?
If you run "ls /dev/io-media/" and then "ls /dev/io-media/graphs/" do
you see the paths?  The output from "pidin ar" and your io-media config
file (if any) might also reveal whether or not this is setup.
Ryan J. Allen
QNX Software Systems
thanks for the advice with 'io-media'.
Taking another version of the driver solved the issue.
