IDE
Tracker
Forum Topic - errno: Page 1 of 2 (28 Items)
errno
I've gotten use to this problem to the point I forgot to mention it.  C++ project, IDE 6.4.1.  For any line that has
errno in it, the editor indicate the line has a syntax error.
Re: errno
Yeah... errno uses some non-standard macro which for some reason indexer cannot find. Qnx project or managed?
> http://community.qnx.com/sf/go/post28371
RE: errno
Managed.
> Sent: April-29-09 2:06 PM
> To: general-ide
> Subject: Re: errno
> C++ project, IDE 6.4.1.  For any line that has errno in it, the editor
> > General
> http://community.qnx.com/sf/go/post28373
Re: errno
Check what it expands to (hover over or open Macro Expansion tool)
If it cannot find _STD macro add it with value of <empty> to Path and Symbols->Symbols tab...
> Managed.
>> -----Original Message-----
>> To: general-ide
>> Subject: Re: errno
>>> General
>> General
> http://community.qnx.com/sf/go/post28374
RE: errno
Is this something we should mention in the release notes?
Steve Reid (stever@qnx.com)
Technical Editor
QNX Software Systems
Re: errno
Nope. There is a lot of weird stuff that indexer cannot parse properly. It does not affect functionality (just a warning
 that can be turned off)
It is not worth mentioning imho.
> Technical Editor
> http://community.qnx.com/sf/go/post28377
RE: errno
> Sent: April-29-09 2:53 PM
> To: general-ide
> Subject: Re: errno
> It does not affect functionality (just a warning that can be turned
> off)
Not working properly is one thing, but having the editor show a warning (question marks and yellow underlines all over
the place) is worth a "don`t spend time search for a solution" release note?
> > Technical Editor
> > General
> http://community.qnx.com/sf/go/post28383
Re: errno
What is the solution for errno btw? Did it work what I said?
There is no universal solution btw...
>> To: general-ide
>> Subject: Re: errno
>> off)
>>> Technical Editor
>>> General
>> General
> http://community.qnx.com/sf/go/post28384
RE: errno
> Sent: April-29-09 3:15 PM
> To: general-ide
> Subject: Re: errno
No it didn`t.  I gave a description of what I saw in another post?
> >> To: general-ide
> >> Subject: Re: errno
> properly.
> >> off)
> warning (question marks and yellow underlines all over the place) is
> >>> Technical Editor
> >>> General
> >> General
> > General
> http://community.qnx.com/sf/go/post28386
Re: errno
Yeah which means _STD expands to ::std::. So if you override it for C it suppose to be gone...
>> To: general-ide
>> Subject: Re: errno
>>>> To: general-ide
>>>> Subject: Re: errno
>> properly.
>>>> off)
>>>>> Technical Editor
>>>>> General
>>>> General
>>> General
>> General
> http://community.qnx.com/sf/go/post28387
RE: errno
> Sent: April-29-09 3:24 PM
> To: general-ide
> Subject: Re: errno
In Paths and Symbols, for languages I only see Assembly and GNU C.  I was expecting GNU C++.  That being said _STD is
defined for GNU C but still no go.
> >> To: general-ide
> >> Subject: Re: errno
> >>>> To: general-ide
> >>>> Subject: Re: errno
> >> properly.
> turned
> >>>> off)
> >>>>> Technical Editor
> >>>>> General
> >>>> General
> >>> General
> >> General
> > General
> http://community.qnx.com/sf/go/post28388
Re: errno
Strange that I cannot reproduce it, I create managed c++ project and add cpp and c file. For each of them errno defined
differently,
Try to enable full indexing in C/C++ General->Indexing in project properties. (It won't cache headers for full indexing
which (caching) is probably case of the error).
Do you include errno.h explicitly in every file that uses it?
>> To: general-ide
>> Subject: Re: errno
RE: errno
> Sent: April-29-09 3:36 PM
> To: general-ide
> Subject: Re: errno
> add cpp and c file. For each of them errno defined differently,
> properties. (It won't cache headers for full indexing which (caching)
I always use Full Indexing.  I use 6.4.1 but the 6.3.2 tools
In the C file I`m checking, it`s there.  There might be some files (project contains huge number of file), that do not
include it explicitly in every file but rather through some other header file.
I creates new dummy C++ project with one C file and one C++ files and just like you I can`t reproduce it.  I'll try to
find out what is different and will get back to you.
> >> To: general-ide
> >> Subject: Re: errno
> C
> was expecting GNU C++.  That being said _STD is defined for GNU C but
> still no go.
> http://community.qnx.com/sf/go/post28395
Re: errno
> (It won't cache headers for full indexing which (caching) is probably case of
> the error).
I manage to create a VERY stripped down version of a project that shows the problem.  Just import it, then load the file
 applications/fusion/init.c and int a = errno;  should be shown as a syntax error.
I looked at the Build Variables and when Show System Variables is activated I can see __cplusplus is present.  That
could explain it?  Because the macro resolved shows errno to be std::...... so it treats the C file as C++.
> >> To: general-ide
> >> Subject: Re: errno
> expecting GNU C++.  That being said _STD is defined for GNU C but still no go.
Re: errno
Woops forgot to attach the file.
Attachment: Text arch.7z 88.68 KB
Re: errno
What it this format? Can you just zip it?
> http://community.qnx.com/sf/go/post29039
RE: errno
> Sent: May-08-09 11:17 AM
> To: general-ide
> Subject: Re: errno
It's 7z,
I will resist, 7z is so much better then zip ;-)
www.7zip.org
Or sudo apt-get install 7za
7za x <file>
You'll never look back. Lol!
> > General
> http://community.qnx.com/sf/go/post29042
Re: errno
Why you such a pain?
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Couldn't find package 7za
>> To: general-ide
>> Subject: Re: errno
> It's 7z,
> www.7zip.org
> 7za x <file>
>>> General
>> General
> http://community.qnx.com/sf/go/post29044
RE: errno
> Sent: May-08-09 11:36 AM
> To: general-ide
> Subject: Re: errno
Lol! You'd have to ask my mother.
Sorry made a typo it's sudo apt-get install p7zip
Just before I got this email I sent you the tgz file ;-)
Re: errno
Anything to please ;-)
> > General
Attachment: Text arch.tgz 111.89 KB
Re: errno
> > > General
Anyone care to look at that.  Now that we have start to deploy 6.4.1 everyone is complaining about this.
Re: errno
Sorry did not have a chance yet. But it has been on my whiteboard as todo for a while! PR #69642.
RE: errno
> Sent: July-06-09 11:36 AM
> To: general-ide
> Subject: Re: errno
Thanks!
> http://community.qnx.com/sf/go/post33187
Re: errno
Probably error in scanner discovery (that tries to guess macro names to be defined for each file). Can you remove
manually __cplusplus var for this file?
If you can attach the project I can look at it...
file applications/fusion/init.c and int a = errno;  should be shown as a syntax error.
RE: errno
> Sent: May-08-09 11:16 AM
> To: general-ide
> Subject: Re: errno
> be defined for each file). Can you remove manually __cplusplus var for
> this file?
How do you propose I do that?  It's a system variable as per the IDE, I can't remove it.
> syntax error.
> activated I can see __cplusplus is present.  That could explain it?
> the C file as C++.
> http://community.qnx.com/sf/go/post29041
