Mario Charest
02/10/2009 12:09 PM
post21911
> Even don't try, it should be done automatically. I let you know how to
> deal with that before long.
Ok thanks!
> On 10/02/2009 12:05 PM, Mario Charest wrote:
> > I try to convert but it says, no converter available.
> > What does MMB mean?
> >> -----Original Message-----
> >> From: Alex Chapiro [mailto:community-noreply@qnx.com]
> >> Sent: February-10-09 11:55 AM
> >> To: general-ide
> >> Subject: Re: C++ build
> >> I see.. This is unfortunate feature of CDT project. As soon as you
> >> change something under the hood, you should convert old stuff.
> Actually
> >> it should work automatically if developer accuratly change version
> of
> >> MMB. I think over how to fix the problem.
> >> Thanks.
> >>>> Sent: February-10-09 11:49 AM
> >>>> To: general-ide
> >>>> Could you please create new project. Does the problem still exist?
> >>> Works ok for new project.
> >>>>>> Sent: February-10-09 11:30 AM
> >>>>>> To: general-ide
> >>>>>> I think you are talking about regular make, don't you?
> >>>>> Yes
> >>>>>> What is the build number?
> >>>>> I20090205
> >>>>> I started noticing when in all of my projects Eclipse could not
> >>>> resolve all standard C/C++d header file. In the Path And Symbol
> >>>> sections the list of path for system header files disappeared.
> >>>>>> On 10/02/2009 11:22 AM, Mario Charest wrote:
> >>>>>>> Since I upgrade to 4.6.0 2009 ! (at least that's when I think
> >> the
> >>>>>> problem started to happend) when I go into a project C/C++
> >>>> properties
> >>>>>> and select any of the option available under C/C++ build I get
> an
> >>>>>> error. Here is what the log file as to say:
> >>>>>>> !ENTRY org.eclipse.jface 4 2 2009-02-10 11:14:01.323
> >>>>>>> !MESSAGE Problems occurred when invoking code from plug-in:
