IDE
Tracker
Forum Topic - Windows echo: (5 Items)
Windows echo
With IDE 4.5.0 The echo command under Windows doesn't seems to process \c anymore. Instead of not doing a line feed \c
is being displayed
Re: Windows echo
 is being displayed
echo.exe is still interpreting escape sequences in 6.4
C:\>C:/QNX630/host/win32/x86/usr/bin/echo.exe "foo\cbar"
foo
C:\>C:/QNX640/host/win32/x86/usr/bin/echo.exe "foo\cbar"
foo
C:\>C:/QNX630/host/win32/x86/usr/bin/echo.exe "foo\nbar"
foo
bar
C:\>C:/QNX640/host/win32/x86/usr/bin/echo.exe "foo\nbar"
foo
bar
Ryan Mansfield
Re: Windows echo
Look like I jumped to conclusion too fast.  Further investigation shows that the issue is with PATH.  Here is what
happen:
Install 6.3.2
Install 6.4.0
Switch config to 6.3.2
Install ch ( C Shell)
Ch modifies the path variable and add its own directory. Because it was installed after the switch to 6.3.2 the path for
 ch ended up at the end of PATH.
When I switched back to 6.4.0 PATH gets modified but the QNX component of the path is not replace, it's first remove and
 then the 6.4.0 get added at the end.  The results is that the order is changed, resulting in chaos.
After switching to 6.4.0 echo was not the one from the 6.4.0 but rather from ch.  I'm even afraid it could be the one
coming windows itself.  I guess the solution is to prefix all commands in our makefile with $QNX_HOST
> anymore. Instead of not doing a line feed \c is being displayed
> foo
> foo
> foo
> bar
> foo
> bar
> Regards,
> Ryan Mansfield
Re: Windows echo
Having not followed this thread closely could you not simply set path explicitly at the beginning of your scripts?
happen:
> Install 6.3.2
> Install 6.4.0
for ch ended up at the end of PATH.
and then the 6.4.0 get added at the end.  The results is that the order is changed, resulting in chaos.
>> foo
>> foo
>> foo
>> bar
>> foo
>> bar
>> Regards,
>> Ryan Mansfield
> http://community.qnx.com/sf/go/post18814
cburgess@qnx.com
RE: Windows echo
> From: Colin Burgess [mailto:community-noreply@qnx.com]
> Sent: January-20-09 3:40 PM
> To: general-ide
> Subject: Re: Windows echo
Guess I could but I prefer to have each command point exactly where I want them to.
> shows that the issue is with PATH.  Here is what happen:
> > Install 6.3.2
> > Install 6.4.0
> was installed after the switch to 6.3.2 the path for ch ended up at the
> end of PATH.
> component of the path is not replace, it's first remove and then the
> resulting in chaos.
> rather from ch.  I'm even afraid it could be the one coming windows
> with $QNX_HOST
> process \c
> >> foo
> >> foo
> >> foo
> >> bar
> >> foo
> >> bar
> >> Regards,
> >> Ryan Mansfield
> > General
> cburgess@qnx.com
> http://community.qnx.com/sf/go/post20448
