Trackers
Trackers
Forum Topic - QNX7.1 / Momentics7.debugger unusable: (1 Item)
Hi, I'm using the QNX7.1 with Momentics Version: 7.1.0.v202006141843
OS: Windows 10, v.10.0, x86_64 / win32 / Java version: 1.8.0_252
GDB Debugger seems to be quite unusable: very slow, impossible to break a running
process if a breakpoint is not reached.
The target system is running ok, I'm able to use telnet sessions and other utilities,
only the under-debug process have problems.
The IDE on PC is frozen and can't be interrupted, it can be forced to quit by windows
but no way to get it working.
On the same PC I've also the QNX6.5(Momentics 4.7.2)/QNX6.6(Momentics 5.0.1)
and when I use them I've no debugging problems (I've  QNX6.5 and QNX6.6 targets).
Maybe there are some incompatibilities between QNX7.1/Momentics7.1 and the
other Qnx/Momentics installation?
Any suggestion ?
Thanks in advance
M. Sangalli
