I`m note sure where the problem comes from but with IDE 5.0 + gdb 7.4 + DSF when starting a debug session the debugger
is unable to load/find the symbols for shared library specified in Shared Librairies tab. But with CDI it works
The extra paths are c:\helios_6_5_0\logc\librairies\lib and c:\opt\poco_1.4.2p_1_QNX650\lib.
With DSF framework
330,051 2-environment-cd C:/helios_6_5_0/logc
330,051 2^done
330,051 (gdb)
330,051 3-gdb-set breakpoint pending on
330,051 3^done
330,051 (gdb)
330,051 4-enable-pretty-printing
330,051 4^done
330,051 (gdb)
330,051 5source .gdbinit
330,051 &"source .gdbinit\n"
330,051 &".gdbinit: No such file or directory.\n"
330,051 5^error,msg=".gdbinit: No such file or directory."
330,051 (gdb)
330,051 6-gdb-set target-async off
330,051 6^done
330,051 (gdb)
330,051 7-gdb-set auto-solib-add on
330,051 7^done
330,051 (gdb)
330,051 8-gdb-set solib-search-path C:/QNX650/target/qnx6/../target-override/x86/lib;C:/QNX650/targe\
t/qnx6/../target-override/x86/usr/lib;C:/QNX650/target/qnx6/x86/lib;C:/QNX650/target/qnx6/x86/usr/li\
b
330,067 8^done
330,067 (gdb)
330,067 9-file-exec-and-symbols C:/helios_6_5_0/logc/applications/parameters_server/obj6/parameters_\
server.exe
330,067 9^done
330,067 (gdb)
330,207 10-target-select qnx g_wolfe:8000
330,238 ~"MsgNak received - resending\n"
330,238 ~"Remote target is little-endian\n"
330,238 10^connected
330,238 (gdb)
330,238 11attach 62382241
330,254 &"attach 62382241\n"
330,254 ~"Attaching to pid 62382241\n"
330,254 =thread-group-started,id="i1",pid="62382241"
330,254 =thread-created,id="1",group-id="i1"
330,254 ~"[New pid 62382241 tid 1]\n"
330,254 12-list-thread-groups --available
330,285 =library-loaded,id="/usr/lib/ldqnx.so.2",target-name="/usr/lib/ldqnx.so.2",host-name="C:/QNX\
650/target/qnx6/x86/usr/lib/ldqnx.so.2",symbols-loaded="0",thread-group="i1"
330,285 ~"Reading symbols from C:/QNX650/target/qnx6/x86/usr/lib/ldqnx.so.2..."
330,285 13-list-thread-groups
330,301 ~"(no debugging symbols found)...done.\n"
330,301 ~"Loaded symbols for C:/QNX650/target/qnx6/x86/usr/lib/ldqnx.so.2\n"
330,301 ~"0xb033f9e0 in _start_ () from C:/QNX650/target/qnx6/x86/usr/lib/ldqnx.so.2\n"
330,301 *stopped,frame={addr="0xb033f9e0",func="_start_",args=[],from="C:/QNX650/target/qnx6/x86/usr\
/lib/ldqnx.so.2"},thread-id="1",stopped-threads="all"
330,301 11^done
330,301 (gdb)
330,301 12^error,msg="Can not fetch data now."
330,301 (gdb)
330,316 14-gdb-set env LD_LIBRARY_PATH = /home/mcharest/logc_head/bin
330,316 13^done,groups=[{id="i1",type="process",pid="62382241",executable="C:/helios_6_5_0/logc/appl\
ications/parameters_server/obj6/parameters_server.exe"}]
330,316 (gdb)
330,316 14^done
330,316 (gdb)
330,316 15-gdb-set --thread-group i1 args -s
330,316 15^done
330,316 (gdb)
330,316 16-exec-continue --thread-group i1
330,332 16^running
330,332 *running,thread-id="all"
330,332 (gdb)
330,503 &"warning: Corrupted shared library list: 0x0 != 0x813e800\n"
330,503 =library-loaded,id="libPocoZip.so.1_4_2p_1",target-name="libPocoZip.so.1_4_2p_1",host-name="\
libPocoZip.so.1_4_2p_1",symbols-loaded="0",thread-group="i1"
330,503 =library-loaded,id="libpartage.so",target-name="libpartage.so",host-name="libpartage.so",sym\
330,503 =library-loaded,id="libm.so.2",target-name="libm.so.2",host-name="C:/QNX650/target/qnx6/x86/\
lib/libm.so.2",symbols-loaded="0",thread-group="i1"
330,519 =library-loaded,id="libsocket.so.3",target-name="libsocket.so.3",host-name="C:/QNX650/target\
/qnx6/x86/lib/libsocket.so.3",symbols-loaded="0",thread-group="i1"
330,519 =library-loaded,id="libPocoFoundation.so.1_4_2p_1",target-name="libPocoFoundation.so.1_4_2p_\
1",host-name="libPocoFoundation.so.1_4_2p_1",symbols-loaded="0",thread-group="i1"
330,519...
