Forum Topic - Draw cmd 0x43 failed ?: (7 Items)
Starting phcalc on an embedded target, prints on console:
the phcalc looks fine though - except for the little light grey 'CE' over the CLR button, which is missing.
What does this mean?
- Malte
RE: Draw cmd 0x43 failed ?
0x43 is Pg_DRAW_TEXT, for some reason the call failed.  What version is
this?  Could a font or font mapping be missing on the target?
-Derek
From: Malte Mundt [mailto:community-noreply@qnx.com]
Sent: Wednesday, August 19, 2009 9:02 AM
To: photon-graphics
Subject: Draw cmd 0x43 failed ?
- Malte
Photon microGUI
http://community.qnx.com/sf/go/post36252
Re: RE: Draw cmd 0x43 failed ?
6.4.1. Yes, it was a missing font. I now touched an empty myfile under /usr/photon/font_repository, then rebooted and
started phcalc. Then I did a find -anewer myfile, and it printed all fonts it recently accessed. One was not included on
 my target. Adding it let the draw cmd error disappear.
- Malte
Re: Draw cmd 0x43 failed ?
I get a draw cmd 0x45 failed running Qnx 6.4.1 on a dell dimension e520. What causes this?
0x43  Pg_DRAW_TEXT
0x45  Pg_DRAW_IMAGE
Your subject says 0x43, but your msg says 0x45 ... in any case, one of
these operations have failed.  If it is indeed 0x43, I would double
check your parameters to text draws ... or try to isolate it in a small
test case.
-Derek
Sent: Tuesday, June 08, 2010 5:57 PM
To: photon-graphics
Subject: Re: Draw cmd 0x43 failed ?
What causes this?
Photon microGUI
http://community.qnx.com/sf/go/post56347
The actual command is 0x45. I am new to QNX. I have just installed QNX on a Dell host with the end idea of porting
drivers from Linux which is what I am familar with. Can you enumerate? Essentialy, whenever I start phgrafx to change my
 display settings the window manager crashes and displays
waiting for desktop manager to start
Draw cmd 0x45 failed
And will hang there forever
RE: RE: Draw cmd 0x43 failed ?
Please contact tech support, and file a bug report, they may have
encountered this already.  It sounds to me that that either io-display
or io-graphics has terminated abnormally.  Please reference this thread
in your ticket submission as well.  Check /var/dumps for any .core
files.
-Derek
Sent: Wednesday, June 09, 2010 2:00 PM
To: photon-graphics
Subject: Re: RE: Draw cmd 0x43 failed ?
on a Dell host with the end idea of porting drivers from Linux which is
phgrafx to change my display settings the window manager crashes and
displays
Photon microGUI
http://community.qnx.com/sf/go/post56419
