Forum Topic - Photon can't switch video mode when at least one GLES application is running: (5 Items)
Photon can't switch video mode when at least one GLES application is running, to reproduce this run gf-ph-3d and try to
switch video mode resolution or color depth on the same resolution. Ideally AFAIU application should receive EXPOSE
event and re-create all GLES stuff, but in practice after attempt of video mode switch, Display Settings utility reports
 about an unknown error.
RE: Photon can't switch video mode when at least one GLES application is running
I have filed a PR67213 for investigation, but just to be clear, it is io-display that would be preventing the mode
switch.
From: Mike Gorchak [mailto:community-noreply@qnx.com]
Sent: Thu 09/04/2009 12:40 AM
To: photon-graphics
Subject: Photon can't switch video mode when at least one GLES application is running
Photon microGUI
http://community.qnx.com/sf/go/post26482
Attachment: Text winmail.dat 3.71 KB
Re: RE: Photon can't switch video mode when at least one GLES application is running
Thanks, Derek. Take a look into sloginfo information after that, it contains a lot of errors, concerning failed to
render command 0x4E or somthing like this.
RE: RE: Photon can't switch video mode when at least one GLES application is running
Yes, that is no surprise, because offscreen is invalidated during modeswitch, and the application is trying to draw
using invalidated surface IDs.  That said, the demo you reference uses a PtRaw for rendering, and not a PtOSContainer,
so the application would have to intercept the expose event itself, and recreate the osc it is using.
-Derek
Sent: Thu 09/04/2009 5:05 AM
To: photon-graphics
Subject: Re: RE: Photon can't switch video mode when at least one GLES application is running
Photon microGUI
http://community.qnx.com/sf/go/post26499
Attachment: Text winmail.dat 3.91 KB
> display that would be preventing the mode switch.
> To: photon-graphics
> running
> to reproduce this run gf-ph-3d and try to switch video mode resolution or
> EXPOSE event and re-create all GLES stuff, but in practice after attempt of
> video mode switch, Display Settings utility reports about an unknown error.
> Photon microGUI
I have finished the investigation of PR67213.
It is because a hybrid GF/Photon application does a gf_dev_attach(), and io-graphics cannot umount the device, which
happens during a grafx restart service message.  This is expected behaviour, and part of the architectural compromises
of GF/Photon co-existance.
Though it is up for debate whether is failing of a mode switch should occur, then reason it happens is now understood.
