Forum Topic - unable to initialise io-display: (1 Item)
I try to initialize io-display in order to start photon but getting any error
I use pci -v to make sure that the VGA display is present but I am still unable to initialize io-display
What am I doing wrong here? Any suggestions? Thank you
# io-display -dvid=0x8086,did=0x1912
Could not initialize device "vid=0x8086,did=0x1912": No such device
Check 'sloginfo' output for more details
io-display failed to initialise
Device ID      = 1912h, Unknown Unknown
PCI index      = 0h
Class Codes    = 030000h
Revision ID    = 6h
Bus number     = 0
Device number  = 2
Function num   = 0
Status Reg     = 10h
Command Reg    = 7h
BIST           = 0h Build-in-self-test not supported
Latency Timer  = 0h
Cache Line Size= 10h un-cacheable
BAR - 0 [Mem]  = de000000h 64bit length 16777216 enabled
BAR - 2 [Mem]  = c0000000h prefetchable 64bit length 268435456 enabled
BAR - 4 [I/O]  = f000h length 64 enabled
Subsystem Vendor ID = 8086h
Subsystem ID        = 2015h
Max Lat        = 0ns
Min Gnt        = 0ns
PCI Int Pin    = INT A
Interrupt line = 9
CPU Interrupt  = 9h
Capabilities Pointer = 40h
Capability ID        = 9h - Vendor Specific
Capabilities         = 10ch - 62016671h
Capability ID        = 10h - PCI Express
Capabilities         = 92h - 10008000h
Capability ID        = 5h - Message Signaled Interrupts
Capabilities         = 0h - 0h
Capability ID        = 1h - Power Management
Capabilities         = 22h - 0h
Class          = System Peripherals (Other)
Device ID      = 1911h, Unknown Unknown
PCI index      = 0h
Class Codes    = 088000h
Revision ID    = 0h
Bus number     = 0
Device number  = 8
Function num   = 0
Status Reg     = 10h
Command Reg    = 6h
Latency Timer  = 0h
BAR - 0 [Mem]  = df716000h 64bit length 4096 enabled
Max Lat        = 0ns
Min Gnt        = 0ns
PCI Int Pin    = INT A
Interrupt line = 9
CPU Interrupt  = 9h
Capabilities Pointer = 90h
Capabilities         = 2h - 0h
Capability ID        = 13h - Unknown
Capabilities         = 306h - 0h
