Forum Topic - Adding data to a PtMTrend: (3 Items)
I'm having some trouble adding data to a PtMTrend widget. I have multiple trends in the same widget and I am trying to
use PtMTrendAddData() so that the trends scroll across the screen. The structure of the code is like below:
std::vector data;
data.resize(20);
// Fill data here
PtMTrendAddData(widget, 0, &data[0], data.size());
// Fill data for second trend here
PtMTrendAddData(widget, 1, &data[0], data.size());
It seems that when I add data to one trend the other gets zero added to it for the same length. I tried to add data for
all trends at the same time, but I could only add to one trend at a time.
Is it possible to use PtMTrendAddData() in this scenario or do I have to maintain my own buffer for each trend into
which I add the new data and change the entire data for each trend on an update using PtMTrendChangeData()?
Thanks.
Re: Adding data to a PtMTrend
It looks like you are doing this from an input callback or a workproc.
Put PtHold()/PtRelease() around the trend updates:
PtHold();
PtMTrendAddData();
PtMTrendAddData();
PtRelease();
Hi Misha,
Yes, I should have said. I am doing this from a thread (using PtEnter() and PtLeave() to get access to the UI).
Your solution works perfectly.
Thank you.
