Forum Topic - Autorun a shell script under photon: (7 Items)
how i can run a shell scirpt after photon ist loaded?
Autologin works very well but i don't know how to start a shell script automatically.
thx.
Georg.
Re: Autorun a shell script under photon
the link from you ist to start photon.
But i will start a other applikation with shell script automatically.
Photon ist running.
Georg.
$HOME/.ph/phapps is the answer.
ok. But i don't understand how to use it.
For ecample i have a shell with the name "start.sh".
The next point is that the description writes:
/etc/system/config/nophoton
    If this file exists, the system doesn't boot into Photon. The file's contents aren't important; you can just touch
the file to create it.
I will that photon starting and then automatically start a tool over a shell script. Like the
autostart in windows.
thx.
Georg.
Additional i use QNX 6.4.1
Georg.
The $HOME/.ph/phapps can be a shell script.
For example put:
/usr/photon/bin/phcalc
into this script. Make sure that it is executable:
chmod +x $HOME/.ph/phapps
Now after you login, you should see the phcalc on the screen.
Also, take a look at the /usr/bin/ph script too to learn more on how things get started.
