Forum Topic - Dynamically updating a PtMultiText widget: (3 Items)
My application has an option to display status messages while it is processing data.
I am attempting to update a PtMultiText widget for each status point in the process.
It isn't working.  Nothing is displayed in the PtMultiText widget until the process has completed and then it is only
the last string, not all of them.
Basically, here is the flow and the code that sets the PtMultiText widget.
void ProcessData()
    //UPDATE THE USER
    AppendMessage("The Process has started\n");
    //DO WORK
    //UPDATE THE USER
    AppendMessage("The Process is 33% done\n");
    //MORE WORK
    //UPDATE THE USER
    AppendMessage("The Process is 66% done\n");
    etc...
    //FINAL UPDATE
    AppendMessage("The Process is done.\n");
void AppendMessage(const char* const pszInMsg)
    char szFullMsg[8192+1] = {0};
    char* pszCurMsg = 0;
    //GET CURRENT TEXT
    PtGetResource(ABW_MultiTxtMsg, Pt_ARG_TEXT_STRING, &pszCurMsg, 0);
    //MERGE BOTH TEXT VALUES
    sprintf(szFullMsg, "%s %s", pszCurMsg, pszInMsg)
    //SET NEW TEXT
    PtSetResource(ABW_MultiTxtMsg, Pt_ARG_TEXT_STRING, szFullMsg, 0);
Re: Dynamically updating a PtMultiText widget
This is expected -- you consume all the "cycles" ;-) -- photon library never gets a chance to process and render the
changes.
You can call PtBkgdHandlerProcess() after each multitext update to do the processing.
Take a look at this chapter: http://www.qnx.com/developers/docs/6.5.0/topic/com.qnx.doc.photon_prog_guide/lengthy.html
It discusses parallel operations.
So, PtSetResource() doesn't actually modify the contents of the widget, it just sets some type of update flag so that it
 is done later, is that correct?
I thought it might be something like that, but I wasn't having any luck finding that in the documentation.
Thank you for pointing me in the right direction, the update process is working correctly now.
I am having another issue, but I will post a separate message about that.
Thanks again!
Kendall
> gets a chance to process and render the changes.
> processing.
