Graphics
Forum Topic - PtOsContainer moving image: (7 Items)
Hi:
I'm writing a demo for a potential customer, I need to be able to have a flicker free indicator move across a graphic
background. This indicator is has been read in using PxLoadImage and has transparent areas.
Ive tried using the PtOsContainer. Its smooth and flicker free - however it has a coloured background and I am unable to
 make it 1) transparent or 2) make its 'fill' the same as the real background.
Q: is there something that I am missing with PtOSContainer?
I am also looking into Video memory offscreen. This has potential. However it draws over the background and I get old
draws still visible as the indicator moves.
Q: Do I need to 'mask' out the previous indicator before blitting the updated one? If so how? Can you point me to sample
 code where the blitted image is moving?
Andy
RE: PtOsContainer moving image
please post your sample code, what OS version are you using?
From: Andy Rhind [mailto:community-noreply@qnx.com]
Sent: January 20, 2011 7:29 PM
To: photon-graphics
Subject: PtOsContainer moving image
Hi:
flicker free indicator move across a graphic background. This indicator
it has a coloured background and I am unable to make it 1) transparent
However it draws over the background and I get old draws still visible
updated one? If so how? Can you point me to sample code where the
Andy
Photon microGUI
http://community.qnx.com/sf/go/post82520
Re: RE: PtOsContainer moving image
Derek:
Sorry about that - I knew exactly what version of the OS I was using :) Its QNX6.5
Ive put together a simple example that shows the PtOsContainer wont accept a transparent background.  Its attached.
This is the simplest and the preferred solution, it would be perfect if you can get transparent working.
I am putting a stand along demo together for the Video offscreen drawing.
Andy
Attachment: Text OsContainerDemo.tgz 95.49 KB
PtOSContainer doesn't accepts transparent background -- just like the PtWindow.
I recommend placing your PtOSContainer as the first child of the PtWindow and making the OSContainer as big as the
window -- use anchors if you need too resize both in sync. Then place all of your widgets into the OSContainer.
RE: RE: PtOsContainer moving image
Hi Andy,
Ok, it will never have transparent background, unless we misunderstood
here, we thought you were trying with a solid colour background or a
The reason is that the PtOSContainer uses offscreen memory to composite
the display, before flipping it to the screen, and thus since it is
already pre-composited, it cannot take into account the content behind
it (*).
Now, you can place the entire contents of the window in a PtOSContainer
(move up the hierarchy).
I am guess what you want is something similar to this:
	Window -> pane (solid colour bkgd) -> buttons etc, draw stuff ->
then a PtOSContainer over top with transparent background
well, we would suggest this:
	Window -> PtOSContainer (solid colour bkgd) -> buttons, etc draw
stuff -> another transparent pane with content with content
-Derek
(*) Now with surface memory, it is always possible to do alpha blending,
etc., but that approach is beyond the reach of the PtOSContainer, and on
systems w/o hardware accelerated alpha blend, it is quite slow.
Sent: January 24, 2011 12:59 AM
To: photon-graphics
Subject: Re: RE: PtOsContainer moving image
Derek:
Its QNX6.5
accept a transparent background.  Its attached.  This is the simplest
drawing.
Andy
Photon microGUI
http://community.qnx.com/sf/go/post82560
Re: RE: RE: PtOsContainer moving image
Thank you Derek & Misha:
Thats the solution!
I was using the PtOSContainer for just the widgets that were changing. Your solution is perfect, put the background then
 the animated label and anything else in the PtOsContainer.
Andy
RE: RE: RE: PtOsContainer moving image
You're welcome, glad it worked!
Sent: January 25, 2011 12:22 AM
To: photon-graphics
Subject: Re: RE: RE: PtOsContainer moving image
Thats the solution!
Your solution is perfect, put the background then the animated label and
Andy
Photon microGUI
http://community.qnx.com/sf/go/post82604
