Forum Topic - Identifying Widget in a Callback: (4 Items)
I have a situation where I need to use the same callback for different buttons. Is there any way to identify the Widget
(button in my case) that triggered the callback?
I looked at the Pt_Widget structure but wasn't able to find any relevant information.
Thanks!
Re: Identifying Widget in a Callback
> . Is there any way to identify the Widget (button in my case) that triggered
> the callback?
> information.
> Thanks!
I'm currently using user data specific to each button to identify them in the callback (Pt_Widget->user_data). I was
just interested to know if Photon has a default/recommended practice for identifying a Widget.
there are at least three different ways to recognize the widget which invoked a callback. One of them, attaching unique
user data to each widget, you already named - and that is often the best way.
Of course you could also compare the 'widget' pointer directly, as in:
   if ( widget == ABW_widget1 ) {
      /* do widget1 processing */
   else if ( widget == ABW_widget2 ) {
      /* do widget2 processing */
   else {
      /* do something else? */
But then it's much nicer to go by the 'widget name' (which is actually an index):
   switch ( ApName( widget ) ) {
   case ABN_widget1:
   case ABN_widget2:
   default:
- Thomas
Ok, thats good to know. Thanks!
