Forum Topic - Alpha blended line caused io-graphics to segfault: (2 Items)
I can reproduce the problem on any graphics driver (including vesabios and svga) in QNX 6.4.1 and in any 32 bpp video
mode, but only with these alpha blending flags: Pg_BLEND_SRC_0 | Pg_BLEND_DST_S and only while drawing lines (some
diagonal lines only, not vertical, not horizontal).
Graphics context has all default values before the following code:
            /* Set light gray fill color */
            PgSetFillColor(PgRGB(160, 160, 160));
           /* Draw the box */
            PgDrawIRect(0, 0, 500, 500, Pg_DRAW_FILL);
            /* Set white line color */
            PgSetStrokeColor(PgRGB(255, 255, 255));
           /* Set and enable alpha blending */
           PgSetAlpha(Pg_BLEND_SRC_0 | Pg_BLEND_DST_S, NULL, NULL, 0, 0);
           PgAlphaOn();
           /* Draw the line over gray box */
           PgDrawILine(242, 47, 237, 452);
           /* Flush */
           PgFlush();
           PgWaitHWIdle();
This piece of code must draw completely invisible line over gray filled box to the current draw context. In 15/16 bpp
video modes all works fine, but in 32 bpp io-graphics is terminated with segmentation fault error.
Re: Alpha blended line caused io-graphics to segfault
Thank you for your report.
I filed a PR on your behalf.
PR#71912.
