                    running openGLES2 apps with screen-api on generic x86 desktop pc with intel i915
              | 06/18/2014 8:50 AM post110745 | running openGLES2 apps with screen-api on generic x86 desktop pc with intel i915
                    Hello to All!
I'm  trying to run gles2-gears example on a generic x86 desktop pc with intel i915 graphics card.
My base is the x86 BSP for qnx 660 - bios version. In build file I added env vars  SCREEN-DIR, GRAPHICS_ROOT and
LD_LIBRARY_PATH. Then I start screen command and the gles2-gears example.
Furthermore I added the original target specific files e.g. graphics.conf, libs, ... to the file system. In graphics.
conf in winmgr section I only changed in framebuffer classes "usage" from "gles2" to "gles2blt" (see release notes http:
//www.qnx.com/developers/articles/rel_5849_7.html).
I also checked all dependencies for all shared libs, it seems to be not the problem!
Running screen still fails with a segmentation fault!
sloginfo says:
Jun 18 14:12:02    5     8   300 screen: starting up...
Jun 18 14:12:02    5     8   300 screen: connected to powman...
Jun 18 14:12:02    6     8   200 wfd_init_driver
Jun 18 14:12:02    7     8   200 init_driver_locked ok
Jun 18 14:12:02    7     8   200 deref_device_handle: bad device handle 0
Jun 18 14:12:02    2     8   200 open_drm_dev failed: No such file or directory
Jun 18 14:12:02    6     8   200 create_internal_device failed, err=2
Jun 18 14:12:02    6     8   200 wfd_deinit_driver starting
Jun 18 14:12:02    7     8   200 wfd_deinit_driver complete
Jun 18 14:12:02    2     8   300 screen: win_enumerate_displays: could not create display device 1
Jun 18 14:12:02    2     8   300 screen: invalid display id:
	>>>   begin display 2
	>>>   begin display 3
Jun 18 14:12:02    5     8   300 screen: loading EGL display 1...
Jun 18 14:12:02    5     8   300 screen: loading blit module gles2blt...
Jun 18 14:12:02    2     8   300 screen-gles2blt: eglInitialize: EGL is not initialized, or could not be initialized,
for the specified display
Jun 18 14:12:02    2     8   300 screen: win_blit_module_init: could not create a blitting context
I hope anybody of you understand what I did wrong!?
Thanks & Regards
