                    QT with OpenGL ES on Beagle board
              | 07/17/2012 3:03 AM post94278 | QT with OpenGL ES on Beagle board
                    Hello everybody,
I'm working on porting QT framework to QNX and I have some problem that I'm stuck at.
I've build QT for QNX and can make it work on Beagle board (armv7 + qnx) except that QtOpenGLES apps can not run. I
means, such QT apps that contain no QTOpenGL code like collidingmice run well while the ones that contain QtOpenGL code
like hellogl_es can not - they just show their window whithout opengl content inside when running.
I've tried QT 4.7.1 as well as 4.8.2 and the result are the same.
I've already install Composition Manager patch.
SGX already run and I can run gles1-gears, gles2-gears, ...
Any help please? Attached is my build file for Beagle board.
Thanks and regards,
DQT |
