Re: Is there any alternative way to post frame to io-winmgr than using eglswapbuffer()?
11/08/2010 12:18 AM
post73799
Thanks in advance.
What does conventional drawing under no io-winmgr mean, exactly ?
What I meant by conventional drawing is drawing only using GF APIs like following.
gf_dev_attach();
gf_display_attach();
gf_layer_attach();
gf_surface_create_layer();
gf_context_create();
gf_context_set_surface(context, surface);
while(1){
gf_draw_begin(context);
drawing_routine();
gf_draw_end(context);
On contrast, if I draw using egl APIs under io-winmgr, it was much slower. The code briefly looks like following.
eglGetDisplay();
eglInitialize();
eglCreateWindowSurface();
gf_context_init();
gf_context_set_surface_3d();
while(1){
drawing_routine();
eglbufferswap();
What is the hardware ?
We are using i.mx31 lit version(which doesn't have MBX). I have tested over VMWare. Other engineer in my team tested
over i.mx31 and showed eglbufferswap() consumes much time.
What are the settings in winmgr.conf ?
begin globals
input = all
end globals
begin display
cursor = sw-arrow
begin plane
egl-config = auto
end plane
end display
Why is CWM necessary in your current design ?
Our graphic provides 2 physical layers. We needed more layers so we use software layers provided from io-winmgr.
