Can we use OpenKODE at VWMARE?
06/24/2010 9:26 PM
post57860
hi,
Can we use the OpenKODE under the following environment:
VMWARE 5.5
QNX 6.4.1
OpenGL Es 1.4
When we call the function kdRealizeWindow( kd_win, &egl_win), the egl_win is NULL.
And can we use it at the Photon Mode?
Confidentiality Notice: The information contained in this e-mail and any accompanying attachment(s)
is intended only for the use of the intended recipient and may be confidential and/or privileged of
Neusoft Corporation, its subsidiaries and/or its affiliates. If any reader of this communication is
not the intended recipient, unauthorized use, forwarding, printing, storing, disclosure or copying
is strictly prohibited, and may be unlawful.If you have received this communication in error,please
immediately notify the sender by return e-mail, and delete the original message and all copies from
your system. Thank you.
Re: Can we use OpenKODE at VWMARE?
06/24/2010 9:28 PM
post57861
Please attach your source code, or at least the initialization pieces.
Jason
On 10-06-24 9:26 PM, "Chen ShunLi" <community-noreply@qnx.com> wrote:
> hi,
> VMWARE 5.5
> QNX 6.4.1
> OpenGL Es 1.4
> is NULL.
> Thanks
> CWM/OpenKODE
> http://community.qnx.com/sf/go/post57860
06/24/2010 9:44 PM
post57862
In fact, the source code is copy from SVN "gles1-kd-pbuffer.c" and be
changed some MACRO such as:
KD_WINDOWPROPERTY_POSITION_QNX==>KD_QNX_WINDOWPROPERTY_POSITION
1. At the photon mode, the kdCreateWindow is failure
2. I change it to Text mode and run the io-winmgr by telnet, the
kdCreateWindow is OK.
But when we call kdRealizeWindow( kd_win, &egl_win), the elg_win is NULL.
Full screen with white background displayed in VMWARE
thanks
06/24/2010 10:30 PM
post57863
OpenKODE apps don¹t run in VMWare.
Can you run egl-configs and put the output here?
Jason
> thanks
> CWM/OpenKODE
> http://community.qnx.com/sf/go/post57862
06/24/2010 10:35 PM
post57864
1. Photon Mode:
| config id | caveat | red | green | blue | luminance | alpha | depth |
stencil | samples | window | pbuffer | pixmap | gles1 | gles2 | vg | gl |
native | level |
| 1 | none | 8 | 8 | 8 | 0 | 8 | 0 |
0 | 0 | | x | x | | | | | x |
0 |
| 2 | none | 8 | 8 | 8 | 0 | 8 | 0 |
0 |
| 3 | none | 8 | 8 | 8 | 0 | 0 | 0 |
0 |
| 4 | none | 5 | 6 | 5 | 0 | 0 | 0 |
0 |
| 5 | none | 5 | 5 | 5 | 0 | 1 | 0 |
0 |
| 6 | none | 0 | 0 | 0 | 8 | 0 | 0 |
0 |
| 7 | slow | 8 | 8 | 8 | 0 | 8 | 0 |
0 | 0 | | x | x | x | | | | |
0 |
| 8 | slow | 8 | 8 | 8 | 0 | 8 | 0 |
16 | 0 | | x | x | x | | | |
| 0 |
| 9 | slow | 8 | 8 | 8 | 0 | 8 | 16 |
0 |
| 10 | slow | 8 | 8 | 8 | 0 | 8 | 16 |
| 0 |
| 11 | slow | 8 | 8 | 8 | 0 | 0 | 0 |
0 |
| 12 | slow | 8 | 8 | 8 | 0 | 0 | 0 |
| 0 |
| 13 | slow | 8 | 8 | 8 | 0 | 0 | 16 |
0 |
| 14 | slow | 8 | 8 | 8 | 0 | 0 | 16 |
| 0 |
| 15 | slow | 5 | 6 | 5 | 0 | 0 | 0 |
0 |
| 16 | slow | 5 | 5 | 5 | 0 | 1 | 0 |
0 |
| 17 | slow | 5 | 6 | 5 | 0 | 0 | 0 |
| 0 |
| 18 | slow | 5 | 5 | 5 | 0 | 1 | 0 |
| 0 |
| 19 | slow | 5 | 6 | 5 | 0 | 0 | 16 |
0 |
| 20 | slow | 5 | 5 | 5 | 0 | 1 | 16 |
0 |
| 21 | slow | 5 | 6 | 5 | 0 | 0 | 16 |
| 0 |
| 22 | slow | 5 | 5 | 5 | 0 | 1 | 16 |
| 0...
06/24/2010 10:45 PM
post57865
I am sorry for disordered information. I add them to Excel file. Please
check it.
