Forum Topic - winmgr.conf more than one display section: (2 Items)
Hello all:
I wanted to clarify a point in winmgr.conf. Now I understand for each physical display you want to target you need a
display section in winmgr.conf. If you don't specify an id (like if you just copied the display section so you have two
identical ones), will the display sections point to the default physical display or will they automatically know to
associate with the next physical display?
If we do in fact need to specify the id I am assuming we use the wfd-device setting and get the value from sysres as
described in the comments.
Gervais
Re: winmgr.conf more than one display section
Thanks JP - wfd-device is actually needed.
