Forum Topic - gf_dev_attach problem on i.mx35 PDK: (8 Items)
I'm attempting to get a simple graphics example up and running in QNX on an imx35. The system boots QNX fine and loads
io-display and Photon as expected. When I get to the point that I run io-graphics, I get the following error:
Jan 01 00:07:04    2     8     0 io-graphics: gf_dev_attach('/dev/io-display/0000,0000,0'): gf errno 7
I'm new at QNX, so I assume I'm doing something simple wrong. searching documentation/google/groups hasn't turned up
anything. Anyone have any insights?
The buildfile is attached.
Attachment: Text build 26.3 KB
Re: gf_dev_attach problem on i.mx35 PDK
Are you able to run vsync or demo-alpha for example on the target? (before you run io-graphics)
both give gf_dev_attach() failed errors with no additional info. (nothing in sloginfo)
demo-alpha also says "Failed to initialize graphics device"
RE: gf_dev_attach problem on i.mx35 PDK
Hi Andy,
	Please "slay io-display", then restart it, but this time, put DL_DEBUG=1 in front of the command (e.g. "DL_DEBUG=1 io-
display ....").  Please capture the output of that, and also would you mind sending the output of sloginfo once io-
display has run?  The output of the following two commands might also be helpful:
1) ls -l /dev/shmem
2) ls -l /dev/io-display
Cheers,
Gaétan
From: Andy Staats [mailto:community-noreply@qnx.com]
Sent: September 1, 2009 3:51 PM
To: advanced-graphics
Subject: Re: gf_dev_attach problem on i.mx35 PDK
Advanced Graphics
http://community.qnx.com/sf/go/post37069
Re: RE: gf_dev_attach problem on i.mx35 PDK
The good news is that my problem apparently "went away" while attempting to gather the log for this response. The bad
news is that I have no idea why. Thanks for all the attention from everyone getting me to this point; I'll see if I can
backtrack my actions to cause the issue to re-appear.
I can now run phcalc and see it appear on my LCD, which was my goal for this exercise.
Attached is the requested info.
Ethernet eth0: MAC address 00:04:9f:00:d8:87
IP: 10.19.8.68/255.255.255.0, Gateway: 0.0.0.0
Default server: 10.19.8.129
hardware reset by watchdog
Clock input is 24 MHz
Booting from [NOR flash]
Chip is working in consumer mode
RedBoot(tm) bootstrap and debug environment [ROMRAM]
Non-certified release, version FSL 200918 - built 09:40:04, Apr 29 2009
Platform: Freescale (i.MX35 ) PASS 2.0 [x32 DDR]
Copyright (C) 2000, 2001, 2002, 2003, 2004 Red Hat, Inc.
Copyright (C) 2003, 2004, 2005, 2006 eCosCentric Limited
RAM: 0x00000000-0x07f00000, [0x000957f0-0x07ed1000] available
FLASH: 0xa0000000 - 0xa4000000, 512 blocks of 0x00020000 bytes each.
RedBoot> load -v -r -b 0x00100000 img.bin
Using default protocol (TFTP)
Raw file loaded 0x00100000-0x004e3b3f, assumed entry at 0x00100000
RedBoot> run
load entry_address=0x100000
virt_addr=0x1L2 cache enabled
CPU0: Dcache: 512x32 WB
CPU0: Icache: 512x32
CPU0: VFP 410120b3
CPU0: 4117b363: arm1136 rev 3 532MHz
System page at phys:80011000 user:fc404000 kern:fc404000
Starting next program at vfe041e74
cpu_startnext: cpu0 -> fe041e74
VFPv2: fpsid=410120b3
coproc_attach(10): replacing fe063c84 with fe063444
coproc_attach(11): replacing fe063c84 with fe063444
Welcome to Neutrino 6.4.0 on the Freescale i.MX35 3DS Board
Starting I2C driver...
Starting SDMA shared resources...
Creating SDMA Infrastructure...
# export DL_DEBUG=1
# io-display -dvid=0,did=0
dlopen("devg-imx35.so",0)
load_object: attempt load of devg-imx35.so
load_elf32: loaded lib at addr 78000000(text) 78008d4c(data)
dlsym(0x10e040,_btext)=0x101bf8
Library loaded; type 'add-sym devg-imx35.so 0x101bf8' in gdb to load symbols
load_object: attempt load of libffb.so.2
load_elf32: loaded lib at addr 78010000(text) 78022d04(data)
load_object: attempt load of libm.so.2
load_elf32: loaded lib at addr 78030000(text) 7805fa10(data)
dlsym(0x10e040,devg_get_modefuncs)=0x7800488c
dlsym(0x10e040,devg_get_memfuncs)=0x780040e4
dlsym(0x10e040,devg_get_miscfuncs)=0x78004598
dlsym(0x10e040,devg_get_vcapfuncs)=NULL
dlsym(0x10e040,devg_shmem_size)=0x780090b0
# sloginfo
# Photon &
[1] 16392
# ls /dev
console        null           ser1           stderr         tty
i2c0           photon         ser2           stdin          tymem
io-display     pipe           shmem          stdout         zero
mem            sem            slog           text
[1] + Done                 Photon
# ls -l /dev/shmem/
total 5
nrw-rw-rw-  2 0         0                28 Jan 01 00:00 SDMA_MUTEX
nrw-rw----  2 0         0              1708 Jan 01 00:00 ctl-0000,0000,0
# ls -l /dev/io-display/
total 0
crw-rw----  1 0         0            0,   1 Jan 01 00:00 0000,0000,0
# io-graphics
load_object: attempt load of libgf.so.1
load_elf32: loaded lib at addr 78000000(text) 78014b7c(data)
load_object: attempt load of libph.so.3
load_elf32: loaded lib at addr 78100000(text) 7820451c(data)
load_object: attempt load of libfont.so.1
load_elf32: loaded lib at addr 78016000(text) 7801d28c(data)
load_object: attempt load of libphrender.so.2
load_elf32: loaded lib at addr 78020000(text) 7805a09c(data)
dlopen("phfont.so",3586)
load_object: attempt load of phfont.so
load_elf32: loaded lib at addr 78060000(text) 78075654(data)
dlsym(0x115040,_btext)=0x103040
Library loaded; type 'add-sym phfont.so 0x103040' in gdb to load symbols
dlsym(0x115040,PHFONT_INTERNAL_API)=0x78075be0
dlopen("/lib/dll/font/FCcore.so",2)
load_object: attempt load of...
RE: RE: gf_dev_attach problem on i.mx35 PDK
Hi Andy,
	I'm glad things are working out for you -- let us know if you still need assistance.
	If you want to do a bit more testing, then as soon as your board image is finished booting, do a "pidin -fA" and post
the results of that, and also run the same tests you have run yesterday (those I asked you to run), but this time, don't
 slay io-display (and don't relaunch it).
Cheers,
Gaétan
Sent: September 1, 2009 4:36 PM
Subject: Re: RE: gf_dev_attach problem on i.mx35 PDK
IP: 10.19.8.68/255.255.255.0, Gateway: 0.0.0.0 Default server: 10.19.8.129 hardware reset by watchdog
RedBoot(tm) bootstrap and debug environment [ROMRAM] Non-certified release, version FSL 200918 - built 09:40:04, Apr 29
2009
Platform: Freescale (i.MX35 ) PASS 2.0 [x32 DDR] Copyright (C) 2000, 2001, 2002, 2003, 2004 Red Hat, Inc.
RedBoot> run
CPU0: VFP 410120b3
System page at phys:80011000 user:fc404000 kern:fc404000 Starting next program at vfe041e74
coproc_attach(11): replacing fe063c84 with fe063444 Welcome to Neutrino 6.4.0 on the Freescale i.MX35 3DS Board
# export DL_DEBUG=1
load_elf32: loaded lib at addr 78030000(text) 7805fa10(data) dlsym(0x10e040,devg_get_modefuncs)=0x7800488c
# sloginfo
# Photon &
[1] 16392
# ls /dev
mem            sem            slog           text
[1] + Done                 Photon
# ls -l /dev/shmem/
total 5
total 0
# io-graphics
load_elf32: loaded lib at addr...
What is the contents of your imx35.conf?
What is the board type? (i.e. what type of imx35 do you have?)
The board is an i.mx35 reference board v2.0
here's the info from imx35.conf
xres=800,yres=480,irq=42,refresh=60,hsw=5,hss=50,hew=50,vsw=2,vss=10,vew=10,dmask=0,cidle=0,csel=0,vpol=0,epol=1,dpol=0,
cpol=0,hpol=0,sdc=1,sharp1=0,sharp2=0,ofmt=18,bright=255
