Forum Topic - How to draw a simplerectangle/polygon using QNX Graphics Framework ?: (11 Items)
Dear All,
I am new to GF. I am using the GF APIs and trying to draw a rectangle/polygon or line on the screen. However I am not
successful.
Could anyone help me out with what could be the issue. The initilization steps seems to be correct. I am attaching the
display.con,pidin mem information and sloginfo & program here.
Graphics driver is i830.
Output is :
Number of displays: 1
Display 0: 1024X768, refresh = 60Hz
Number of layers: 4
Attaching to Layer : 2
Format returned by find_rgb_format = 5152
Layer is of Format 5152
Succesfully created surface on top of layer
Created the context succefully
Context Surface is Set Succesfully
Please give your inputs.
Lejin
Attachment: Compressed file GF.zip 5.88 KB
Re: How to draw a simplerectangle/polygon using QNX Graphics Framework ?
You are missing the gf_layer_update(). Put it after the gf_draw_end(),
and make sure that you don't exit immediatelly because it will turn off the display -- I suggest to put in:
   gf_layer_update( layer, 0 );
   printf( "press ENTER to continue\n" );
   getchar();
after the gf_draw_end().
Also your code prints errors but doesn't exit -- for example if the layer attach fails it prints the error, and
continues -- this can/will cause a crash later.
   This is Swetha (Lejin's colleague),
      I had tried with what u have said, we r still facing problems.
  I have attached the modified code in the below attachment
 please chk
Attachment: Text program_GF.c.c 5.39 KB
What exactly are the problems?
I ran your app and it displayed a white rectangle on the screen -- I believe it is correct.
The code has chunks of code commented out -- you may want to clean it up to make it easier to look through.
   This is the output we r getting we run the application
    Number of display : 1
   Display 0: 1024x768, refresh = 60hz
   Number of layers : 4
   successfully created surface on top of the layer
   Created the context succesfully
   context Surface is Set Succesfully
   Press ENTER to continue
  but there is no any image coming up,
I am attaching the
display.con,pidin mem information and sloginfo of the above  program here.
Attachment: Text info.rar 3.8 KB
> I am attaching the
It looks like you are also running Photon io-graphics at the same time. I suggest to try to run your application while
not running Photon.
Do you see your white rectangle?
   I tried to run the application without  the photon,
 but still i could not see the white rectangle
   i am compiling it as below, is it fine?
  gcc program_GF.c -lgf
  ./a.out
   Its working!!, Thanks a lot,
   I had to uncomment the below line in the code.
     if (gf_layer_attach(&layer,display,display_info.main_layer_index,0)
    == GF_ERR_OK) {
