Forum Topic - gf_layer_attach() failed !!!: (8 Items)
Dear All,
Dear All,
I am new to qnx GF, I have read “Advanced Graphics Developers Guide.pdf” and trying to draw a rectangle on GF. I have
x86 target machine connected to QNX Momentics IDE 4.7.
gf_layer_attach() is failed... can some help...
find output and code below.
Output:
Number of displays: 1
Display 0: 1024X768, refresh = 60Hz
Number of layers: 1
code snippet:
#include <stdio.h>
#include <stdlib.h>
#include <gf/gf.h>
int main() {
//device & display
gf_dev_t            gdev;
gf_dev_info_t       gdev_info;
gf_display_t        display;
gf_display_info_t   display_info;
int i;
//layer
gf_layer_t  layer;
//surface
gf_surface_t    surface;
unsigned height;
unsigned width;
gf_layer_info_t layer_info;
//context
gf_context_t context;
if (gf_dev_attach(&gdev, GF_DEVICE_INDEX(0), &gdev_info) != GF_ERR_OK) {
    printf("gf_dev_attach() failed\n");
    return (-1);
printf("Number of displays: %d\n",gdev_info.ndisplays);
for (i = 0; i < gdev_info.ndisplays; i++) {
    printf("Display %d: ", i);
    if (gf_display_attach(&display, gdev, i, &display_info) == GF_ERR_OK) {
        printf("%dX%d, refresh = %dHz\n", display_info.xres,
            display_info.yres, display_info.refresh);
        printf("Number of layers: %d\n", display_info.nlayers);
    } else {
        printf("gf_display_attach() failed\n");
if (display != NULL) {
    if (gf_layer_attach(&layer,display,display_info.main_layer_index, 0) == GF_ERR_OK) {
    //if(gf_layer_attach(&layer,display,0, 0) == GF_ERR_OK) {
		printf("Attaching to Layer : 2\n ");
    else {
        printf("gf_layer_attach() failed\n");
if((gf_layer_query(layer,0,&layer_info))==GF_ERR_OK){
	printf("Layer is of Format %d\n",layer_info.format);
else{
	printf(" gf_layer_query() failed");
width = display_info.xres;
height = display_info.yres;
if (gf_surface_create_layer(&surface, &layer, 1, 0,
width, height, layer_info.format, NULL, 0) == GF_ERR_OK) {
		printf("Succesfully created surface on top of layer\n");
        gf_layer_set_surfaces(layer, &surface, 1);
        /* draw stuff here */
    } else {
        printf("gf_surface_create_layer() failed\n");
if (gf_context_create(&context) != GF_ERR_OK) {
        fprintf(stderr, "gf_context_create failed\n");
        return -1;
else{
printf(" Created the context succefully\n");
if (gf_context_set_surface(context,surface)!= GF_ERR_OK) {
            fprintf(stderr, "gf_context_set_surface failed\n");
            return -1;
 else{
        printf("Context Surface is Set Succesfully\n");
gf_draw_begin(context);
gf_context_set_fgcolor(context,0xFFFFFF);
gf_draw_rect(context,10,10,50,50);
gf_context_set_fgcolor(context,0x000000);
gf_draw_rect(context,20,20,40,40);
gf_draw_end(context);
gf_dev_detach(gdev);
return 0;
Attachment: Text draw.c 2.51 KB
RE: gf_layer_attach() failed !!!
What is the return value from gf_layer_attach()?
From: Ashwini Dubey [mailto:community-noreply@qnx.com]
Sent: November-27-12 2:02 AM
To: advanced-graphics
Subject: gf_layer_attach() failed !!!
Dear All,
Dear All,
Output:
Number of layers: 1
code snippet:
#include <stdio.h>
#include <stdlib.h>
#include <gf/gf.h>
int main() {
//device & display
gf_dev_t            gdev;
int i;
//layer
gf_layer_t  layer;
//surface
unsigned height;
unsigned width;
//context
    return (-1);
    } else {
    else {
	printf("Layer is of Format %d\n",layer_info.format); } else{
if (gf_surface_create_layer(&surface, &layer, 1, 0, width, height, layer_info.format, NULL, 0) == GF_ERR_OK) {
    } else {
        return -1;
else{
printf(" Created the context succefully\n"); }
            return -1;
 else{
return 0;
Advanced Graphics
http://community.qnx.com/sf/go/post97473
To cancel your subscription to this discussion, please e-mail advanced-graphics-unsubscribe@community.qnx.com
Re: RE: gf_layer_attach() failed !!!
Return Value =  0x8
which is GF_ERR_INUSE..
I have installed qnx on i5 intel machine....and i can connect to it and run basic hello world...
i can use web browser too.
RE: RE: gf_layer_attach() failed !!!
What else is running on the machine?  Is Photon running?  You only have one layer on your machine, so no other graphics
environment or application can be running.
Sent: November-28-12 3:45 AM
Subject: Re: RE: gf_layer_attach() failed !!!
Return Value =  0x8
Advanced Graphics
http://community.qnx.com/sf/go/post97541
Re: RE: RE: gf_layer_attach() failed !!!
I have a default installation and basic GUI is running.
Is Photon running?
Yes.
176152   1 /photon/bin/Photon  10r RECEIVE     1
Number of layers: 1
I am very new to QNX, but I am experienced in linux application and kernel development.
Currently I am using intel HD Graphics, PCI device, Vendor ID:8086, Device ID:0152.
please suggest what I need to draw a rectangle or circle or line.
Below is list of all the process running. Result of pidin command.
     pid tid name               prio STATE       Blocked
       1   1 boot/procnto-instr   0f READY
       1   2 boot/procnto-instr 255r RECEIVE     1
       1   3 boot/procnto-instr  10r RECEIVE     1
       1   4 boot/procnto-instr  10r RUNNING
       1   5 boot/procnto-instr 255r RECEIVE     1
       1   7 boot/procnto-instr  10r RECEIVE     1
       1   8 boot/procnto-instr  10r RECEIVE     1
       1  10 boot/procnto-instr  10r RECEIVE     1
       1  11 boot/procnto-instr  10r RECEIVE     1
       1  12 boot/procnto-instr  10r RECEIVE     1
       1  15 boot/procnto-instr  10r RECEIVE     1
       1  16 boot/procnto-instr  10r RECEIVE     1
       2   1 sbin/tinit          10o REPLY       1
    4099   1 proc/boot/pci-bios  10o RECEIVE     1
    4100   1 proc/boot/slogger   10o RECEIVE     1
    4101   1 proc/boot/io-usb    10o SIGWAITINFO
    4101   2 proc/boot/io-usb    21r RECEIVE     4
    4101   3 proc/boot/io-usb    21r RECEIVE     7
    4101   4 proc/boot/io-usb    21r RECEIVE     1
    4101   5 proc/boot/io-usb    10o RECEIVE     10
    4101   6 proc/boot/io-usb    10r NANOSLEEP
    4101   7 proc/boot/io-usb    10o RECEIVE     10
    4101   8 proc/boot/io-usb    10o RECEIVE     10
    4102   1 proc/boot/io-hid    10o SIGWAITINFO
    4102   2 proc/boot/io-hid    21r RECEIVE     1
    4102   4 proc/boot/io-hid    10o RECEIVE     4
    4102   5 proc/boot/io-hid    10r REPLY       4101
    4102   6 proc/boot/io-hid    10r REPLY       4101
    4102   7 proc/boot/io-hid     9r RECEIVE     12
    4102   8 proc/boot/io-hid     9r RECEIVE     16
    4102   9 proc/boot/io-hid    10o RECEIVE     4
    4103   1 /boot/devc-con-hid  20o RECEIVE     1
    4103   2 /boot/devc-con-hid  10o REPLY       4102
    8200   1 roc/boot/devb-eide  10o SIGWAITINFO
    8200   2 roc/boot/devb-eide  21r RECEIVE     1
    8200   3 roc/boot/devb-eide  21o RECEIVE     7
    8200   4 roc/boot/devb-eide  10o RECEIVE     4
    8200   5 roc/boot/devb-eide  10o RECEIVE     4
    8200   6 roc/boot/devb-eide  10o RECEIVE     4
    8200   7 roc/boot/devb-eide  10o RECEIVE     4
    8200  10 roc/boot/devb-eide  10o RECEIVE     4
    8200  13 roc/boot/devb-eide  10o RECEIVE     4
RE: RE: RE: gf_layer_attach() failed !!!
If you want to use Photon, ypu must use Pg photon drawing lines, please see helpviewer in Photon.
If you want to use GF application, then you must exit Photon to text mode, then to make it easy, telnet into the QNX box
, then run the GF application.
Sent: November-29-12 3:16 AM
Subject: Re: RE: RE: gf_layer_attach() failed !!!
Is Photon running?
Yes.
Number of layers: 1
    8200   4 roc/boot/devb-eide ...
Re: RE: RE: RE: gf_layer_attach() failed !!!
Can you please provide example of working GF drawing code.
Do let me also know how to toggle between GUI and text mode.
RE: RE: RE: RE: gf_layer_attach() failed !!!
Please contact tech support for this level of support.
Sent: November-29-12 10:20 AM
Subject: Re: RE: RE: RE: gf_layer_attach() failed !!!
Advanced Graphics
http://community.qnx.com/sf/go/post97622
