Forum Topic - Migration from Photon to GF: (4 Items)
Application is responsible for displaying data (8-bits/pixel graymap). Data is received from Ethernet interface and
displayed when image is complete (all frames were already gathered).
Under Photon as solution I use PhCreateImage() and  PgDrawPhImage() functions.
BTW Is there any other way in order to achive a better performane in Photon ?
It's time to move to GF.
In the "Working with Images" chapter there is a following code:
    palette.ncolors = 256;
    palette.colors = (img_color_t*)g8pal;
but compiler says that g8pal is undefined. How can I use this ?
Should I generate array of colors itself (in similar way that was done under Photon,  PgSetPalette()) ?
What function should I use under GF as equivalent ?
I found the gf_draw_image() but this function doesn't support GF_FORMAT_PAL8...
Jacek
Re: Migration from Photon to GF
I am having the same problem, I can't find 'g8pal'. It looks like it should be a pointer to a palette of type
'img_color_t' which is just an integer. So what should the g8pal palette look like. I am new to QNX and GF graphics and
am finding it hard to get things working as a lot of info is missing from QNX examples.
I have changed pixel_format in the display.conf file from "rgb565" onto "pal8" value.
Now the gf_draw_blit2() works while with "rgb565" screen is dark all the time.
Picture is visible but colors are not correct.
I wonder how to generate 8-bits gray palette under GF ?
I have successfully generated 8-bits gray palette as follows:
gf_palette_t palette;
gf_color_t     g8pal[256];
for (i = 0; i < 256; i++) {
	g8pal[i] = (0xff << 24) | ((i & 0xff) << 16) | ((i & 0xff) << 8) | (i & 0xff);
palette.colors = (gf_color_t*)g8pal;
It works fine with rgb565 format for io-display.
