Forum Topic - Problem for gf-calib: (7 Items)
I am using TI beagle-board. When I use gf-calib for calibration of my touch screen, the following message displays:
# gf-calib
Number of layers: 3
Resolution: 720x400, refresh = 60Hz
layer_idx=0
gf_cursor_set(): error = 7
I have no idea how to solve it. Any help?
Re: Problem for gf-calib
> # gf-calib
> Number of layers: 3
> layer_idx=0
Try the -D option. Also, you need to have "img.conf" under /etc/system/config, plus the img_codec so's in your library
path.
- Malte
Afetr including img.conf and img_codec so's i am getting error as
Number of layers: 3
layer_idx=0
img_load(target1): errno = 3
load_image2surf(): failed
Please help.
Try running your application with "LD_DEBUG=1 {your-app}". You should see which library your are missing.
I got the same problem:
# gf-calib  -D -f /tmp/calib.conf
Number of layers: 1
Resolution: 800x480, refresh = 60Hz
layer_idx=0
switch_lcd_on
switch_lcd_off
could any guys help me
I met the same problem。
# gf-calib -D -f /fs/mmc/config/calib.localhost
Number of layers: 1
layer_idx=0
Do you solve this problem?
please reference the QNX650\target\qnx6\etc\system\config\img.conf.This is helpful.
