Graphics
Forum Topic - What are the basics of font rendering?: Page 1 of 2 (18 Items)
I'm sure this is my own failure to understand the obvious, but if somebody could give me some pointers it would be very
helpful.  The application program I am working on continually reads jpg and/or png files, manipulates them in various
ways, then writes out a bmp file, using the graphics framework.  There is no user interface.  Photon is not running. The
 application works fine, except that I now find I need to render text onto the images, and can't figure out even the
basic steps to do so.
That's my general problem, but far as specifics are concerned, I have two questions to start with:
1.  Given that Photon isn't being used, what software can I use as a font server, and what are the specifics of
obtaining and starting up that software outside of a Photon-related context?
2.  How does one interact with the font server within the context of the graphics framework to get the text rendered
into memory-buffered imagery?  The names of specific API functions would be very helpful.
Thanks!
Re: What are the basics of font rendering?
-- start 'phfont -d /usr/photon/font_repository' -- this will run the server -- you do not need photon
-- use PfAttach(), PfRender(), etc API to render the fonts -- http://www.qnx.com/developers/docs/6.5.0/topic/com.qnx.doc
.photon_lib_ref/pf-base.html
Re: What are the basics of font rendering? [bcc]
Thanks, Misha, that's very useful.  The platform I'm working on is
actually a CAR system that doesn't seem to have phfont on it, but if I
copy a copy of phfont over from QNX 6.5.0, it seems to run and not complain.
However ... as soon as my app tries to use any of the API's font-related
functions there's a segfault.  Recall that I'm not running Photon.  I
wonder if there's some kind of initialization I'm supposed to be doing
that would normally have been done by starting Photon?  Or, could a
versioning discrepancy in phfont be the problem?
Or perhaps I simply don't know what I'm doing in regard to text
rendering.  Is there a suitable coding tutorial somewhere?  (Remember
... I don't have any user interface here, so any tutorial that involves
displaying stuff in windows in Photon is of limited use to me.)
Thanks again!
doc.photon_lib_ref/pf-base.html
> Advanced Graphics
> http://community.qnx.com/sf/go/post85666
I am not aware of a Pf*() tutorial. I recommend starting with the sample code that is in PfRender() API docs.
Also check that:
-- you are running pfont,
-- check sloginfo,
-- see where the app is crashing.
Re: What are the basics of font rendering? [bcc] [bcc][auto-ip]
What is pfont? If you meant phfont, yes ps shows that it's running.
> Also check that:
> -- check sloginfo,
> Advanced Graphics
> http://community.qnx.com/sf/go/post85678
phfont ;-)
Thanks, Misha, I hadn't gotten as far as trying to render the text, so I
hadn't yet become aware of that sample code.  More on that below.
> Also check that:
Here's what "ps -Af | grep phfont" says:
     0    1163315          1  - May16 ?        00:00:00 phfont -d
> -- check sloginfo,
As far as sloginfo is concerned, the following lines seem to be the only
relevant ones:
May 16 07:53:10    1     8     0 phfont: init...
May 16 07:53:10    1     8     0 phfont: initialized.
May 16 07:53:10    1     8     0 phfont: '/dev/phfont[<32|64>]' server
installed.
As I understand it, what the sample code in the PfRender() docs say to
do is:
   1. Run PfAttach().
   2. Run PfFindFont().
   3. Run PfRender().
I segfault the very first time I hit PfFindFont().  Here's the relevant
code-snippet from my program:
   FontServer = PfAttach (NULL, 0);
   if (FontServer == NULL)
       fprintf (stderr, "Cannot attach to font server.\n");
       goto Error;
   for (i = 0; i < 3; i++)
     for (j = 0; j < NUM_FONT_SIZES; j++)
         int FontSize;
         FontID *ID;
         FontSize = MIN_FONT_SIZE + INC_FONT_SIZE * j;
         ID = PfFindFont (FontDescriptions[i], FontStyles[i],
             FontSize);
         if (NULL == ID)
             fprintf (stderr, "Cannot find font %s size %d style 0x%X\n",
                 FontDescriptions[i], FontSize, FontStyles[i]);
         FontStructures[i]->ID = ID;
At the point where the segfault occurs in PfFindFont():
    * FontDescriptions[i] is a pointer to the string "ronsanss", which
      is a TrueType font that I've installed and is known-good (at least
      in Linux).  When I say I've "installed" it, I mean that I hope I
      installed it correctly and that one of the lines in
      /usr/photon/font_repository/fontdir is "ronsanss,0@RonSans.ttf,Ron
      Sans,0,,000D-FFFD,p,228x151,4508K".  Please recall that I'm not
      running Photon, so I'm not aware of any good way to know that the
      installation was correct until my app actually works.
    * FontStyles[i] is 16 (PF_STYLE_ANTIALIAS).
    * FontSize is 10.
> Advanced Graphics
Oops! I was a bit to hasty in the code snippet I sent in my last
message.  Here's a better one:
       goto Error;
         int FontSize;
         FontID *ID;
         FontName Description;
         if (NULL == PfGenerateFontName (
             FontDescriptions[i], FontStyles[i], FontSize, Description))
             fprintf (stderr, "Cannot get font name %s size %d style
0x%X\n",
             return (1);
         ID = PfFindFont (Description, FontStyles[i], FontSize);
         if (NULL == ID)
             return (1);
Here the segfault occurs as soon as PfGenerateFontName() is hit.  The
arguments to PfGenerateFontName() correspond to the description I gave
for the arguments of PfFindFont() in my last message.  In point of fact,
the segfault occurs if I simply run the sample code in the
PfGenerateFontName() doc:
       goto Error;
       char szHelvetica12[MAX_FONT_TAG];
       if (PfGenerateFontName ("Helvetica", PF_STYLE_BOLD, 12,
szHelvetica12)
           == NULL)
           perror ("Unable to find font");
This is likely that you are trying to use photon wrapper functions, and since you are not connected to photon they fail.
Change the code to use Pf*Cx() API. For example PfGenerateFontNameCx(). It takes an extra parameter which is a struct
_Pf_ctrl * -- the one returned by the PfAttachCx().
Well, you're right that it doesn't segfault with
PfGenerateFontNameCx().  The next problem is that no matter what
pkgDescription argument I plug into PfGenerateFontNameCx(), the function
always returns NULL.  I guess the names from the fontdir file are not
what is supposed to be in pkgDescription.  Certainly, the string
"Helvetica" as given in the sample code doesn't work.  How can I find a
valid pkgDescription to plug in?
fail.
> Advanced Graphics
> http://community.qnx.com/sf/go/post85711
