Forum Topic - HMI Player 1.1.0 system clock setting problem: (3 Items)
All movies in flash stop playing when i set the system clock back in time, the same with setInterval() in actionscript.
Freezing interval somehow depends on difference between old and new time settings. For example, if i set system time
back for 1 min, the movie in flash freezes for ~1 min.
I tried flash-gf on 6.4 and flash-ph on 6.3.2 with same results. HMI Player version is 1.1.0, purchased from SWD
Software.
Any help will be appreciated.
Alexander
Re: HMI Player 1.1.0 system clock setting problem
Are you able to update your player to the one in HMI Suite 2.0?  The player
was not using a monotonic clock for some of its timing functions so
advancing or retarding the system time would have the same effect on its
clock.  This problem was fixed some time after the release of the 1.1
player.
Unfortunately, I can't think of any way of working around it other than
upgrading your flash player.
Thank you, Roger.
How can i upgrade 1.1 player to 2.0 version? I don't find any patches in download section.
