Graphics
Forum Topic - Poulsbo and screen resiolution: Page 1 of 3 (27 Items)
On my system (see attached get_hw_info) I'm using the devg-poulsbo.so as video driver.
http://www.qnx.com/developers/docs/6.4.1/neutrino/utilities/d/devg-poulsbo.so.html
It works fine with a resolution of 1024 x 768. But if I tried to set the resolution to 1280 x 1024 it failed and go back
 to 1024 x 768.
See all messages at the end of the sloginfo but the most important seems to be:
/usr/photon/bin/io-graphics: gf_dev_attach('/dev/io-display/8086,8108,0'): gf errno 2
Any idea why this error occurs?
Christophe
Attachment: Text hw-info-localhost_4.txt 58.28 KB
RE: Poulsbo and screen resiolution
Can you tell us what board this is and what type of display you are
using?
Can you exit to text mode and run 'show_vesa' and post the output?
From: Christophe Hannoyer [mailto:community-noreply@qnx.com]
Sent: January 15, 2010 11:43 AM
To: advanced-graphics
Subject: Poulsbo and screen resiolution
video driver.
bo.so.html
resolution to 1280 x 1024 it failed and go back to 1024 x 768.
to be:
Christophe
Advanced Graphics
http://community.qnx.com/sf/go/post45314
Re: RE: Poulsbo and screen resiolution
Thanks for the reply.
The board:
http://www.men.de/products/15MM01-.html
The display it's a BENQ FP91G+.
And the show_vesa is attached to this message.
Christophe Hannoyer
Attachment: Text show_vesa_1.txt 23.61 KB
The board:
Christophe Hannoyer
> -----Message d'origine-----
> De : Michael Van Reenen [mailto:community-noreply@qnx.com]
> Envoyé : lundi 18 janvier 2010 18:40
> À : advanced-graphics
> Objet : RE: Poulsbo and screen resiolution
> using?
> Thanks
> video driver.
> bo.so.html
> to be:
> Thanks,
> Christophe
> Advanced Graphics
> Advanced Graphics
> http://community.qnx.com/sf/go/post45412
I believe with this setup the driver will end up trying to use the video BIOS to set the graphics mode. (in particular
sDVO output likely to DVI or VGA)
The output of show_vesa lists 1024x768 but not 1280x1024 which is the issue.
Unfortunately with the current driver there is no way to override using of the BIOS.  We hope to address this in a
future release.
Sent: January 19, 2010 8:50 AM
Subject: RE: Poulsbo and screen resiolution
The board:
Christophe Hannoyer
> using?
> Thanks
> video driver.
> bo.so.html
> to be:
> Thanks,
> Christophe
> Advanced Graphics
> Advanced Graphics
Advanced Graphics
http://community.qnx.com/sf/go/post45470
Hello Michael,
Thank you for your reply.
Only to know you are involved in this driver development?
Anyway waiting for a new release fixing this I will also tried to see with the BIOS developer to know if he can fixed
this at the BIOS level.
We will see which of these two solutions will be available first.
Christophe Hannoyer
> Envoyé : mercredi 20 janvier 2010 03:45
> to set the graphics mode. (in particular sDVO output likely to DVI or VGA)
> BIOS.  We hope to address this in a future release.
I create an image with a small demo running Photon. I run this image without any problem on an Atom Z530. A customer is
using this image on an Atom Z510 and he get the error :
when starting io-graphics.
I attach to this post the show_vesa. I notice some difference with the previous I posted here but I don't know if thias
can explain that.
Any idea ?
Christophe
Attachment: Text show_vesa_2.txt 39.66 KB
RE: RE: Poulsbo and screen resiolution
What resolution and color depth are they trying to run at?
Mike
Sent: March 15, 2010 12:37 PM
Subject: Re: RE: Poulsbo and screen resiolution
without any problem on an Atom Z530. A customer is using this image on
gf_dev_attach('/dev/io-display/8086,8108,0'): gf errno 2 when starting
io-graphics.
previous I posted here but I don't know if thias can explain that.
Any idea ?
Christophe
Advanced Graphics
http://community.qnx.com/sf/go/post49496
Re: RE: RE: Poulsbo and screen resiolution
Hello Mike,
Thank you for the reply. They try to run at 1024x768 rgb565.
Christophe
> Thanks
> Mike
> Hello,
> io-graphics.
> Any idea ?
> Thanks,
> Christophe
> Advanced Graphics
Attachment: Text display.conf 302 bytes
RE: RE: RE: Poulsbo and screen resiolution
Does it work if they try settings refresh to 60?
Mike
Sent: March 16, 2010 4:43 AM
Subject: Re: RE: RE: Poulsbo and screen resiolution
Hello Mike,
Christophe
> Thanks
> Mike
> Hello,
> io-graphics.
> Any idea ?
> Thanks,
> Christophe
> Advanced Graphics
Advanced Graphics
http://community.qnx.com/sf/go/post49570
