Forum Topic - Jade - how to get 1280x480 working ?: (7 Items)
Customer is using the stock Jade BSP on a reference board.
They enabled just the 1280x480 mode in jade.conf, along with a pixel format of argb1555 i.e. display.conf is:
device{
	drivername=jade
	vid=0
	did=0
	deviceindex=0
	modeopts=/etc/system/config/jade.conf
	display{
		xres=1280
		yres=480
		refresh=60
		pixel_format=argb1555
They enable just the existing 1280x480 line in jade.con
When they start it, they get:
# gf_dev_attach(): No error
sloginfo returns:
Jan 01 00:00:00    2     8   200 io-display: driver doesn't support, or not configured for "argb1555" at 1280x480, 60Hz
Any clues ?
Thanks !
Dave
RE: Jade - how to get 1280x480 working ?
Hey Dave,
Do you have the complete jade.conf and sloginfo?   If so can you post it
here?
Mike
Sent: November 3, 2009 4:42 PM
To: advanced-graphics
Subject: Jade - how to get 1280x480 working ?
device{
	drivername=jade
	vid=0
	did=0
	deviceindex=0
	display{
		xres=1280
		yres=480
		refresh=60
sloginfo returns:
Any clues ?
Thanks !
Dave
Advanced Graphics
http://community.qnx.com/sf/go/post41272
Customer says:
I set the resolution back to 1024x768 and the program runs fine with no error messages.
As for the sloginfo there is only that one message:
It's not clear to me how the jade.conf file precisely matches the mode that is specified in display.conf. Where does
argb1555 fit in ?
If it is hdp and vdp, along with refresh, it might be nice to document that.
Are these files any help ?
Here's the non-working display.conf and jade.conf .
Regards
Dave
display.conf
device{
	drivername=jade
	vid=0
	did=0
	deviceindex=0
	display{
		xres=1280
		yres=480
		refresh=60
jade.conf:
# devg-jade.so parameters for tailoring to specific boards and display modes.
# See MB8601 Jade Graphics Display Controller Specification for further details.
# Board-specific options:
# vidbase	Video Base Address (if PCI card, this value is ignored)
# regbase 	Register Base Address (if PCI card, this value is ignored)
# vsize 	Amount of video memory
# irq		Interrupt number for InterruptAttach()
# setup		Setup mode and memory (1 = setmode, 0 = keep current setup)
# dlsize	memory size for 1 drawlist (in bytes)
# anti          global anti-aliasing : 0 = off 1 = on (currently only supports lines)
# hw_tl         enable hw_acceleration of thick_lines : 0 = off 1 = on
# phl           main display default layer: 0-5
# dlayers       SC0en & SC1en fields for Multi-Display Control register (display 0)
# dmode         Dual Display mode (display 0) (0 = single display, 1 = dual parallel mode, 2 = dual multiplexed mode)
# logsw3d	Report 3D software fallback events to the system logger (warning: very verbose, diagnostic only): 0 = off 1 =
on
# dlayers1      SC0en & SC1en fields for Multi-Display Control register (display 1)
# dmode1        Dual Display mode (display 1 (0 = single display, 1 = dual parallel mode, 2 = dual multiplexed mode)
# nocap1	Do not configure multiplexing pins for video capture unit 1 (0 configure pins for capture1, 1 - do not
configure pins)
# Note on the logsw3d option:
# The information captured to the system logger contains a "reason" bitmask,
# which specifies the rendering feature which could not be accelerated.  The
# bits in the bitmask are defined as follows:
# Stencil Test                        0x00000001
# Unsupported blend mode              0x00000002
# Unsupported Logical Operation       0x00000004
# Unsupported Texture feature         0x00000008
# Color Mask                          0x00000080
# Alpha Test                          0x00000100
# Fog                                 0x00000200
# The driver will use the first un-commented entry.
# Note: these are sample values and may need to be adjusted for your specific board
# Jade Starter Kit (JADESK) evaluation board
irq=32,regbase=0xf1fc0000,vsize=0x1000000,setup=1,dlsize=2048,anti=0,hw_tl=1,phl=2
# Multiplexed dual-display Jade Starter Kit (JADESK) evaluation board (display 0)
#irq=32,regbase=0xf1fc0000,vsize=0x1000000,setup=1,dlsize=2048,anti=0,hw_tl=1,phl=2,dmode=2,dlayer=0xffff
# Mode specific options: modes corresponding to uncommented entries will be
# available to applications.
# Note: For multiplexed dual display mode (dmode != 0), the DCM SC field must be adjusted to double to the clock rate!
# Display 0 Parameters
# htp		Horizontal Total Pixels
# hdp		Horizontal Display Period
# hsp		Horizontal Synchronize pulse Position
# hsw		Horizontal Syncronize pulse Width
# vsw 		Vertical Synchronize pulse Width
# vtr		Vertical Total Rasters
# vsp		Vertical Synchronize pulse Position
# vdp		Vertical Display Period
# dcm		Display Control Mode 1 register
# refresh	Refresh rate (in Hz)
# Display 1 Parameterrs (only used in parallel independant dual display)
Attachment: Text winmail.dat 8.71 KB
Thanks for this additional information.
The framework will take the xres, yres, refresh, and pixel_format
specified in display.conf and query the driver for all supported
resolutions/refresh/pixel_formats to see if there is a match.
The slog message below indicates that the frame work couldn't find a
match.
In the case of the Jade (and many of the other embedded platforms) it
will only support a single resolution based on the settings in
jade.conf.  The driver should use the first uncommented 'mode' line.
I agree that it's not clear how all the pieces fit together especially
in this case.  Some other drivers have a bit better detail.
You're correct that hdp and vdp in jade.conf need to match xres and yres
in the display.conf.   argb1555 is the pixel format and the only one
that Jade will use. (it can do 8-bit but the framework doesn't support
this)
Looking at the config files below I don't see anything that appears to
be incorrect.   In case its some kind of formatting thing they may want
to delete all other 'mode' entries completely from the file.
Mike
Sent: November 3, 2009 10:36 PM
Subject: RE: Jade - how to get 1280x480 working ?
Customer says:
error messages.
that is specified in display.conf. Where does argb1555 fit in ?
that.
Regards
Dave
display.conf
device{
	drivername=jade
	vid=0
	did=0
	deviceindex=0
	display{
		xres=1280
		yres=480
		refresh=60
jade.conf:
modes.
details.
ignored)
setup)
supports lines)
(display 0)
(warning: very verbose, diagnostic only): 0 = off 1 = on
(display 1)
unit 1 (0 configure pins for capture1, 1 - do not configure pins)
bitmask,
The
# Color Mask   ...
Good call Mike - and thanks for all of the detailed info too !
Customer says:
Okay, I cleaned up the file, rebuilt and the error is gone, the driver seems to be working.
The only problem is the output is set for ARGB only. From what I can tell the sil164 on the eval board supports both
Analog and DVI-D, it just needs to be switched over via I2C. Can this be done through the display driver? Or do you have
 another driver handle the configuration?
Any suggestion on the output control ?
Thanks !
Dave
From: Michael Van Reenen [mailto:community-noreply@qnx.com]
Sent: Wed 04/11/2009 6:25 AM
match.
this)
Mike
Customer says:
error messages.
that.
Regards
Dave
display.conf
device{
        drivername=jade
        vid=0
        did=0
        deviceindex=0
        display{
                xres=1280
                yres=480
                refresh=60
jade.conf:
modes.
details.
ignored)
setup)
supports lines)
(display 0)
# logsw3d       Report 3D software fallback...
Attachment: Text winmail.dat 13.95 KB
Our driver doesn't touch the SIL164 - so if they want to update the
settings they would need to do this through an external application
through I2C.
Unfortunately I've not worked with this part myself so I don't have much
in the line of suggestions but from what I recall it is a fairly simply
device.
I know we have an I2C driver for the Jade (used it for video capture to
setup the video decoder) so it may be fairly easy to write a small app
to do this change.
Mike
Sent: November 4, 2009 3:26 PM
Customer says:
tell the sil164 on the eval board supports both Analog and DVI-D, it
display driver? Or do you have another driver handle the configuration?
Thanks !
Dave
match.
this)
Mike
Customer says:
error messages.
that.
Regards
Dave
display.conf
device{
        drivername=jade
        vid=0
        did=0
        deviceindex=0
        display{
                xres=1280
                yres=480
                refresh=60
jade.conf:
modes.
details.
ignored)     ...
That's too bad.
Thanks for letting me know, and for the much appreciated support !
Dave
Sent: Wed 04/11/2009 1:04 PM
through I2C.
device.
to do this change.
Mike
Customer says:
Thanks !
Dave
match.
this)
Mike
Customer says:
error messages.
that.
Regards
Dave
display.conf
device{
        drivername=jade
        vid=0
        did=0
        deviceindex=0
        display{
                xres=1280
                yres=480
                refresh=60
jade.conf:
# devg-jade.so parameters for tailoring to specific...
Attachment: Text winmail.dat 14.83 KB
