Brenda Spaur
Can't crop video in GF after initial setup
Brenda Spaur
09/29/2009 6:31 PM
post39027
I'm using the GF video-capture API to display video on an ADS5121. At the end of "Using the Video-Capture API" (http://
cvs.qnx.com/developers/docs/6.4.0/gf/dev_guide/vidcap.html) it says:
"At this point the video-capture device is started, and it's sending video to the layer we bound to it. You can now
adjust the appearance of the video by:
- cropping the captured video by using gf_vcap_set_input_viewport() "
I can call gf_vcap_set_input_viewport() during initial video setup then it works fine and the video is cropped as
desired. If I try to call gf_vcap_set_input_viewport() after the video has been running for awhile then the call seems
to have no effect. I am calling gf_vcap_update() after the the call to set input viewport. I also verified that both
GF_LAYER_CAP_PAN_SOURCE and GF_LAYER_CAP_PAN_DEST are enabled by calling gf_layer_query.
I need to be able to dynamically crop the incoming video. Any thoughts? Do I need to disable and then enable video
capture or the layer the video is being displayed on? If it matters, the video is being displayed on the main layer.
Thanks.
