Forum Topic - usblauncher creation: (4 Items)
What would I do to initialize the usblauncher so i can update the necessary usb descriptors when making the i.MX6
SabreLite a Client/Device.  I am trying to initialize the feature during the bootscript and I am unable to see the /etc/
usblauncher/ directory.
Specifications:
QNX6.6 with BSP
i.MX6 SabreLite
Thanks.
RE: usblauncher creation
To get the /etc/usblauncher directory: the files are on your host (e.g. D:\qnx660\target\qnx6\etc\usblauncher) and you'd
 need to modify the build file for the BSP so that they are included in the IFS, or otherwise mount a filesystem that
has these files so they are available on the target.
You'll need to start pps, usblauncher with a config file with the Host_Stack and Device_Stack sections enabled (the /etc
/usblauncher/rules.lua has them commented out, remove --[[ and --]] markers to do this) then refer to
http://www.qnx.com/developers/docs/660/topic/com.qnx.doc.dev_pub.ref_guide/topic/usblauncher_stack_modes.html
and
http://www.qnx.com/developers/docs/660/index.jsp?topic=%2Fcom.qnx.doc.dev_pub.ref_guide%2Ftopic%
2Fusblauncher_config_usb_descriptors.html
for updating the USB descriptors.
On the target
# pps
# mkdir /pps/qnx
# usblauncher -vvv -c /etc/usblauncher/rules.lua
The usblauncher command-line options are described here:
http://www.qnx.com/developers/docs/660/index.jsp?topic=%2Fcom.qnx.doc.dev_pub.ref_guide%2Ftopic%2Fusblauncher_usage.html
Cheers,
Andy
From: Christopher Olarti [mailto:community-noreply@qnx.com]
Sent: Thursday, June 12, 2014 2:17 PM
To: general-filesystems
Subject: usblauncher creation
Specifications:
QNX6.6 with BSP
i.MX6 SabreLite
Thanks.
General
http://community.qnx.com/sf/go/post110678
To cancel your subscription to this discussion, please e-mail general-filesystems-unsubscribe@community.qnx.com
Re: RE: usblauncher creation
Thanks for the response.  However, when looking for the .build file that I should update, I came across  3 other .build
files.  The following is the original .build file that I am using:
/prebuilt/armle-v7/boot/build/sabrelite.build
However, the following are other .build files that I found:
/src/hardware/startup/boards/imx6x/sabrelite/build.build
/src/hardware/support/appsmedia-sample/appsmedia-sample-common.build
/src/hardware/support/appsmedia-sample/appsmedia-sample-imx6.build
Also when looking in the build scripts themselves, I am not exactly sure where to include the usblauncher location from
the Host... If the modification is in sabrelite.build, then would it be under .console.sh when setting the environment
variables, or would it be with .bootstrap when identifying the PATHs and LD_LIBRARY_PATH.
Thanks.
RE: RE: usblauncher creation
Is your build file setup so that an inserted SD card is mountable? Maybe for starters, it'll be easier for you to copy
over the 'usblauncher' binary and /etc/usblauncher files to the SD card and mount it after the system is booted, instead
 of modifying the IFS.
What is the location of the qnx660 install?
If for example the location (on Linux) is /opt/qnx660
then you'll find the etc files here:
/opt/qnx660/target/qnx6/etc/usblauncher
The executable binary here
/opt/qnx660/target/qnx6/armle-v7/bin/usblauncher
If your SD card is DOS, you could copy the binary to /dev/shmem, then set it executable (chmod +x usblauncher). For
development purposes you can also mount a DOS filesystem as executable to run Neutrino binaries from it.
Help working with BSPs:
http://www.qnx.com/developers/docs/660/index.jsp?topic=%2Fcom.qnx.doc.neutrino.building%2Ftopic%2Fbsp.html
Making the IFS with 'mkifs' via the command-line:
http://www.qnx.com/developers/docs/660/index.jsp?topic=%2Fcom.qnx.doc.neutrino.utilities%2Ftopic%2Fm%2Fmkifs.html
Note: for general questions about usblauncher, feel free to post to the OS Meta forum:
http://community.qnx.com/sf/discussion/do/listTopics/projects.core_os/discussion.metawiki
For BSP-specific questions you can post to the BSP forum:
http://community.qnx.com/sf/discussion/do/listTopics/projects.bsp/discussion.bsp
Cheers,
Andy
Sent: Thursday, June 12, 2014 5:33 PM
Subject: Re: RE: usblauncher creation
Thanks.
General
http://community.qnx.com/sf/go/post110684
