Filesystems
Forum Topic - qnx6f max file number: (5 Items)
Is it unrealistic or does it have some sort of negative impact to have a 2TB disk with qnx6fs and specify something like
 -i 100M ( 100 millions) to mkqnx6fs ?
By the way would be nice if the doc on mkqnx6fs would specify the exact numbers use by the -T option.
RE: qnx6f max file number
Each inode requires 128 bytes, so 100M inodes is 12.8GB, plus the
indirect blocks.  Finding a free inode in a mostly-full system would be
time expensive at that scale.  What you are saying is that you expect
your 2TB drive to be filled up with 10KByte average-sized files.  Having
said that, I know that the test group here has a 2TB server set up with
10M inodes.
mkqnx6fs uses the hint of -T to guess at the average file size.  The
number of inodes are then selected based on that.
The (current, but might change) values are:
Desktop:  1024 byte block,  8 blocks/file
Media:    2048 byte block,  512 blocks/file
Runtime:  1024 byte block, 32blocks/file
David
> From: Mario Charest [mailto:community-noreply@qnx.com]
> Sent: September 20, 2010 9:01 AM
> To: general-filesystems
> Subject: qnx6f max file number
> like -i 100M ( 100 millions) to mkqnx6fs ?
> Thanks
> http://community.qnx.com/sf/go/post67848
> -----Message d'origine-----
> De : David Sarrazin [mailto:community-noreply@qnx.com]
> Envoyé : 20 septembre 2010 09:55
> À : general-filesystems
> Objet : RE: qnx6f max file number
> Each inode requires 128 bytes, so 100M inodes is 12.8GB, plus the indirect
> blocks.  Finding a free inode in a mostly-full system would be time expensive
> at that scale.  What you are saying is that you expect your 2TB drive to be
> filled up with 10KByte average-sized files.  Having said that, I know that the
> test group here has a 2TB server set up with 10M inodes.
That would be 20K files ;-)  I exaggerated that number a bit to get a good idea. Files will be 400K so 5 millions would
be closer to what we need.
Can you define 'time expensive'?  The hardware driver will operate almost 90% full, with around 100 files new files
written and the 100 oldest files deleted.
Thanks David.
> mkqnx6fs uses the hint of -T to guess at the average file size.  The number of
> David
> > a 2TB disk with qnx6fs and specify something like -i 100M ( 100
> > Thanks
> > General
> http://community.qnx.com/sf/go/post67858
Re: RE: qnx6f max file number
> expensive
> the
> idea. Files will be 400K so 5 millions would be closer to what we need.
> full, with around 100 files new files written and the 100 oldest files deleted
Given mkqnx6fs -i12000000 on a 2Terabyte disk filled at 8% is it possible that a write of 20 files (20Meg) will cause
the filesystem to freeze for 10-20Sec ?
RE: RE: qnx6f max file number
Sent: January-24-11 7:26 PM
Subject: Re: RE: qnx6f max file number
> expensive
> the
I would expect no.  If you've used up most of the inodes, and have just a few free holes spread about in the inodes file
, then finding a free inode will incur a search through the file (a hint to where to start searching is stored).  If
this was a new filesystem, the inodes file will be almost entirely free, and finding new entries will be very fast.
Does a KEV show what the "fsys_resmgr" threads in devb are doing?
David
General
http://community.qnx.com/sf/go/post82603
