Forum Topic - HAM Manger do not work as I expected: (10 Items)
I am planning to make some basic use of HAM manager starting our process, however, I have come across some strange
problem.
The code I have write is:
int main(int argc, char *argv[])
	ham_entity_t* ehdl;
	ham_condition_t* chdl;
	ham_action_t* ahdl;
	ham_connect(0); //Connect to HAM.
	if(!(ehdl = ham_attach("vgham",0,0,"/usr/sbin/vgapp",0)))
		perror("ehdl");
	if(!(chdl = ham_condition(ehdl,CONDDEATH,"death",HREARMAFTERRESTART)))
		perror("chdl");
	if(!(ahdl = ham_action_restart(chdl,"vgapp_restart","/usr/sbin/vgapp",HREARMAFTERRESTART)))
		perror("ahdl");
	ham_disconnect(0); //Connect to HAM.
	return EXIT_SUCCESS;
the program I want to keep restarting is:
	procmgr_daemon( EXIT_SUCCESS, 0x000000FF );
	sleep(1);
	fprintf(stderr,"Welcome to the QNX Momentics IDE\n");
	sleep(1);
what I am expect is process 2 keep restarting
After I start process, the second process will start
However  when the second process exit, nothing happend
The magic thing is, if I "slay syslogd" or "syslogd",
process 2 will be restart once
it seems each time I call or slay syslogd, it will action once
is this a HAM bug, or what I have missing in my second process?
Re: HAM Manger do not work as I expected
what version are you using.
shiv
Wed Sep 16 12:56:22 EDT 2009
 --> According to Ji Dong <--
	process, however, I have come across some strange problem.
		ham_entity_t* ehdl;
		ham_action_t* ahdl;
			perror("ehdl");
		if(!(chdl =
			perror("chdl");
		if(!(ahdl =
	TART)))
			perror("ahdl");
		sleep(1);
		sleep(1);
	OSTech
	http://community.qnx.com/sf/go/post38066
Shiv Nagarajan,
Kernel Developer, QNX Software Systems,
Ottawa, Canada
AW: HAM Manger do not work as I expected
is HAM capable of detecting the change of process' state from a regular child to a detached daemon?
when you start the process first, it's a child and you detect starvation through a normal SIGCHLD,
but when the process is doing the procmgr_daemon()
you have to use a pulse through PROCMGR_EVENT_DAEMON_DEATH
as I can't find any special constants for a daemon in ham_condition()
I am asking how ham would detect whether it's a daemon or a child?
BTW: what happens when you just skip that procmgr_daemon() call?
/hp
-----Ursprüngliche Nachricht-----
Von:	Shiv Nagarajan [mailto:community-noreply@qnx.com]
Gesendet:	Mi 16.09.2009 18:52
An:	ostech-core_os
Cc:
Betreff:	Re: HAM Manger do not work as I expected
shiv
		ham_entity_t* ehdl;
		ham_action_t* ahdl;
			perror("ehdl");
		if(!(chdl =
			perror("chdl");
		if(!(ahdl =
	TART)))
			perror("ahdl");
		sleep(1);
		sleep(1);
	OSTech
Shiv Nagarajan,
Ottawa, Canada
OSTech
http://community.qnx.com/sf/go/post38084
Attachment: Text winmail.dat 4.42 KB
the ham registers for the procmgr_event when any daemon process dies.
And then it looks through its list of monitored processes. So it should
be able to detect the death any process that calls procmgr_daemon also.
ham registers for
procmgr_event_notify(PROCMGR_EVENT_DAEMON_DEATH...)
the reason I wanted to know the version, was because a PR 65295 was
fixed which was an issue similar to this.
shiv
Wed Sep 16 15:10:13 EDT 2009
 --> According to Hans-Peter Reichert <--
	/hp
	An:	ostech-core_os
	Cc:
	shiv
			ham_entity_t* ehdl;
			ham_action_t* ahdl;
				perror("ehdl");
			if(!(chdl =
				perror("chdl");
			if(!(ahdl =
		TART)))
				perror("ahdl");
			sleep(1);
			sleep(1);
		OSTech
	Shiv Nagarajan,
	Ottawa, Canada
	OSTech
received this e-mail in error) please notify the sender immediately and delete this e-mail. Any...
Not very sure what version it is, and how to get the ham version.
It comes with QNX 6.4.0 DVD package.
and HAM is running on QNX BSP for freescale mpc8313 v6.4.0
I have attached the "ham" binary for your information.
> ham registers for
> shiv
Attachment: Text ham 107.81 KB
This appears to have been built
DESCRIPTION=High Availability Manager
DATE=2008/10/21-00:21:48-EDT
STATE=Stable
HOST=trunkbuild
USER=builder
VERSION=6.4.0
since that other PR I was mentioning was fixed feb 2009, in all
likelihood, the bug exists in your version. Let me try and get you a ppc
binary from the latest source for you to try.
thanks
shiv
> dies.
> should
> also.
> > ham registers for
> > shiv
> http://community.qnx.com/sf/go/post38131
Shiv Nagarajan,
Ottawa, Canada
E-mail: shiv@qnx.com
> STATE=Stable
> HOST=trunkbuild
> USER=builder
> VERSION=6.4.0
> thanks
> shiv
> > dies.
> > should
> > also.
> > > ham registers for
> > > shiv
> > OSTech
> Shiv Nagarajan,
> Ottawa, Canada
Thanks shiv
I am expecting your new Binary:)
Attached is the ham from 6.4.1 for ppc.
do let me know if this works better.
thanks
shiv
Fri Sep 18 10:52:50 EDT 2009
	> STATE=Stable
	> HOST=trunkbuild
	> USER=builder
	> VERSION=6.4.0
	ppc
	> thanks
	> shiv
	> > dies.
	> > should
	> > also.
	> > > ham registers for
	was
	> > > shiv
	> > OSTech
	> Shiv Nagarajan,
	> Ottawa, Canada
	Thanks shiv
	OSTech
	http://community.qnx.com/sf/go/post38248
Shiv Nagarajan,
Ottawa, Canada
Attachment: Text ham 100.01 KB
Hi shiv:
Thanks for your help, the binary works perfect.....
> thanks
> shiv
Re: AW: HAM Manger do not work as I expected
Hi Hans-Peter Reichert:
Initially I have not call procmgr_daemon(), it is the same. and I have search around and not quite understand something
like, it  have to run on "session 1" so have to use procmgr_daemon() instead of daemon(), so I just give a try, and this
 do not really help.
Because currently all our software is single thread, and have not actually spawn any child process, not sure what harm
will cause if I use procmgr_daemon() to run the process in the backgrand.
Cheers
Ji
> /hp
