Forum Topic - sysconf() and invalid names: (4 Items)
The code for sysconf() includes this comment:
  // POSIX says that sysconf returns -1 and does not set errno
  // when the 'name' is valid and has no limit. If 'name' is invalid,
  // it returns -1 and sets errno to EINVAL. What, exactly, is an
  // invalid 'name' isn't specified. For right now, we assume that
  // all 'name' values are OK, and _conf_get returning -1 indicates
  // that 'name' is unset. Assume, for PCTS, that -1 is never valid.
I would have expected that any name that isn't a defined _SC_* name would be invalid. If you call sysconf() with a bogus
 value -- I tried -377 (which I assume doesn't correspond to an _SC_* name) -- the function returns -1 but doesn't set
errno. It sets errno to EINVAL only if you pass a name of -1.
Is this the right thing for this function to do?
Re: sysconf() and invalid names
One of the sources of values is from the typed_strings section of the
system page. We didn't want to disallow users from defining their own
private set of name/value pairs that we didn't know about, so it seemed
best to define all possible names as valid and just unset.
	Brian
bogus value -- I tried -377 (which I assume doesn't correspond to an _SC_* name) -- the function returns -1 but doesn't
set errno. It sets errno to EINVAL only if you pass a name of -1.
> http://community.qnx.com/sf/go/post37143
RE: sysconf() and invalid names
> From: Brian Stecher [mailto:community-noreply@qnx.com]
> Sent: September 2, 2009 10:52 AM
> To: ostech-core_os
> Subject: Re: sysconf() and invalid names
> section of the system page. We didn't want to disallow users
> from defining their own private set of name/value pairs that
> we didn't know about, so it seemed best to define all
It should be possible for _conf_get to distinguish between unset and
non-existent though, correct?
> 	Brian
> is invalid,
> doesn't set errno. It sets errno to EINVAL only if you pass a
> name of -1.
> > OSTech
> Canada K2M 1W8
> http://community.qnx.com/sf/go/post37149
Not really.
On Wed, Sep 02, 2009 at 10:59:31AM -0400, David Sarrazin wrote:
> > To: ostech-core_os
> > 	Brian
> > is invalid,
> > name of -1.
> > > OSTech
> > Canada K2M 1W8
> > OSTech
> http://community.qnx.com/sf/go/post37153
