Forum Topic - SIGDEADLK clarification: (8 Items)
Hallo folks,
I have a question about SIGDEADLK. I got sporadically this signal with QNX 6.3.2 and a multithread application.
Looking into the Web and into the QNX documentation I did not completely understand when exactly the kernel deliver such
 signal...
Moreover, what it is really strange is that I'm getting (sporadically) such signal once I try to lock a static allocated
 mutex (initialized with PTHREAD_MUTEX_INITIALIZER). This mutex is also never destroyed (no call to
pthread_mutex_destroy)...
Thanks for your help,
-Claudio
Re: SIGDEADLK clarification
See http://www.qnx.com/developers/docs/6.4.1/neutrino/sys_arch/ipc.html#id20
Cheers,
Colin
Claudio Gregorio wrote:
> Hallo folks,
such signal...
allocated mutex (initialized with PTHREAD_MUTEX_INITIALIZER). This mutex is also never destroyed (no call to
> -Claudio
> http://community.qnx.com/sf/go/post36218
cburgess@qnx.com
Thanks Colin,
I already read that doc but it is unclear to me the exact meaning of:
"...and if the conditions that would cause the kernel to deliver the event occur, then the kernel delivers a SIGDEADLK
instead."
If I understand correctly the only condition should be if the mutex enters the DEAD state, BUT how can I get this state
with a static mutex initialized with PTHREAD_MUTEX_INITIALIZER and never destroyed?
Are there any other case where I can get this event?
Many thanks for your help,
-Claudio
is there a way to found out which thread / call issued the SIGDEADLK signal?
Is SIGDEADLK only caused by munmap()? If not, what are the possible functions causing SIGDEADLK to be raised?
Thanks in advance,
Loïc
Can you capture it in a kernel trace?
> Thanks Colin,
 instead."
state with a static mutex initialized with PTHREAD_MUTEX_INITIALIZER and never destroyed?
> -Claudio
> http://community.qnx.com/sf/go/post36228
cburgess@qnx.com
Hi Colin
That's extremely difficult for the target application, unfortunately.
Loïc (on behalf of Claudio)
Is the static mutex in a shared lib?  The SIGDEADLK can only be generated by an unmap killing the mutex.
> Thanks Colin,
 instead."
> -Claudio
cburgess@qnx.com
Hello Colin,
the mutex is part of a static library, declared as static and initialized through PTHREAD_MUTEX_INITIALIZER.
-Claudio
