Forum Topic - Kernel Lock times / Operations to avoid ?: (7 Items)
I'm working with a customer who has very hard realtime requirements when it comes to interrupt latency and the absence
of jitter when receiving interrupts.
I know our kernel is preemptible, but I believe that sometimes the kernel has to lock (disable) interrupts in order to
do some things where it needs to be 'alone' and cannot be interrupted. Is this correct?
Which operations are having the longest lock periods on them? For example, I believe that creation and termination of
processes can cause significant jitter in interrupt latency, so should be avoided in hard realtime situations. What
other operations should be avoided?
- Malte
Re: Kernel Lock times / Operations to avoid ?
The kernel lock affects thread scheduling latency - raw (ISR) interrupt latency
is not affected by the kernel lock at all, although the handling of sigevents
will be deferred until the locked kernel call exits the kernel.
The obvious places where the kernel lock can be held for some time are:
- process creation and termination
- thread creation and termination
- mapping/unmapping memory
- signal deliver to large numbers of processes (eg. big process groups)
	Sunil.
Malte Mundt wrote:
> - Malte
> http://community.qnx.com/sf/go/post33021
Thanks for the info. This sounds as if procnto never disables interrupts, can you confirm?
- Malte
RE: Kernel Lock times / Operations to avoid ?
No, that's not true.  We do disable interrupts for very short periods of time, as a mutual exclusion mechanism.  Plus
some CPUs disable exceptions of all sorts (interrupts included) when they take an exception, and it takes a few dozen
instructions before the kernel gets exceptions enabled again.
From: Malte Mundt [mailto:community-noreply@qnx.com]
Sent: Mon 7/6/2009 4:51 AM
To: ostech-core_os
Subject: Re: Kernel Lock times / Operations to avoid ?
- Malte
OSTech
http://community.qnx.com/sf/go/post33143
Attachment: Text winmail.dat 2.71 KB
Re: RE: Kernel Lock times / Operations to avoid ?
Thanks Doug - are there certain kernel calls the customer should avoid in hard realtime situations, to not run into this
 Interrupt Lock situations?
- Malte
All system calls have interrupts disabled for a very short time (a few
dozen instructions) during the transition into the kernel.  There are a
number of places in cpu-specific code where we disable interrupts,
typically while mucking around with TLBs or address spaces.
Instrumented kernels sometimes disable interrupts while storing events.
Aside from that, in common code, there are only a couple of places we
disable interrupts and those situations are typically only a few lines
of code -- on the same order as the transition-into-kernel code.
So, aside from avoiding the instrumented kernel (Colin?  Care to comment
on the effects of -instr variants on hard realtime systems?) I'd say
there's nothing specific to avoid.
Doug
this Interrupt Lock situations?
> - Malte
> http://community.qnx.com/sf/go/post33795
Good info, thanks!
- Malte
